Lights on, pedal won't depress, takes few tries to start. Is this a battery problem?
Well I have another problem with my new 2015 RX 350 that I just bought a few days ago. On two separate occasions, I have gotten into the car, pushed the brake pedal whilst pressing the Start button, and the brake pedal does not depress. It stays firm, and all the lights come on, but the car doesn't start. After a few repeated tries, it will eventually start. It happened tonight, took a few tries, then it started, I drove one mile to a friend's house, and then two hours later when I left, it started just fine.
Is this a battery problem? Or likely something else ? I looked at the Carfax report the dealership gave me and it does show "battery checked" a few times it doesn't say battery "replaced." I'm hoping that's all it is but with the pedal not depressing and the lights coming on, I am not sure?
Seems to me a dealer selling a used car with a seven-year-old battery would replace it before selling it to avoid bad reviews, but I don't know.
Just get the battery tested.
Salim
Salim
When you depress the brake, does the READY light come on BEFORE you press the START button? I had this problem when I first got my 2011 RX450h (10 year old battery at the time). When I would press both at the same time, it would not start, and at first I was not waiting for the ready light, before pressing the start button. So the starting sequence should be... Brake, Ready Light then Start.
No reason a dealership would replace the battery if it starts everytime for them, whenever they move the car. Bought my car in April 2021 with its original battery, carfax and maintenance records showed that the battery had also been "checked", along with other items, none of which were replaced unless needed. Some batteries last longer than others, winter and summer may be the true test on whether a battery needs to be replaced. So get the battery and charging system checked out, just to rule out the battery needing to be replaced. Considering it's one of the easier components to diagnose and replace, that would be one of my first steps.
The dealership, was it a Toyota/Lexus dealer or a mixed vehicle used car lot? If the latter, they are less likely to put any money into a vehicle, past washing and a vacuuming. Most won't even replace burnt out exterior/interior lights unless a buyer notices before money changes hands. The truly shady dealers, will paint over undercarriage rust, do and engine detail (Vaseline) seared on the plastic and rubber hoses and tires to make it look good.
I stood over his shoulder and watched and it came back "Good Battery." There was a sticker on the battery that said 1/22, presumably when the dealer seller last checked it. Who, by the way was a Lexus dealer. I would go back to the same place but it's 3 hours away.
Anyway hopefully this sequence thing is the issue and I will monitor the situation. My research said possible brake light switch or master cylinder problem but the Autozone guy said he thinks the computer needs to be reset.
Now you have eliminated the battery as an issue.
I know this is obvious, but make sure you are consistently pressing the brake pedal hard enough to engage the bypass start switch or whatever they call it that requires the brake to be pressed to start it. I have this issue in my Sienna sometimes and just think it is an operator error due to my driving 4 different vehicles and they are all a little different.
