Radio and Air Conditioning Control Panel InoperativeI
I have a 2014 Lexus Rx350 , Canada built I believe , without Navigation.. It has 66,000. miles on it.
The Radio/Air Cond controls in the middle of the dash are not working...you press the buttons and nothing happens .and the Lexus dealer says it is the " radio control unit assembly " that needs replacement........about $2880. !!!
I did some research and I believe the affected part number is 86120-OE450 ( P10175 radio )...but i am still working to verify that.
I really only need the air to work......The radio is not a priority..........But the dealer says the AIR COND controls go thru the radio.......so the whole thing needs to be replaced.
My thought is to take the whole RADIO/CONTOl unit out and send for repair at an electonics shop. I have seen some YOUTUBE videos on uninstall/install , they dont look too bad...... and i have started to explore repair shops in the area and nationwide.
I have two questions :
1) Wil the car be oprational after I take the unit out ? or there are other things connected to that radio/control unit the make the car unusable.......like airbags headlights/brakelights, etc
2) has anybody done anything similar to correct this issue ?
Thank you so much in advance !!
Welcome to CL. You are not the first one with this failure. Below are links to 2 older threads with similar, but not exact failures. However you are probably facing either a new one, repairing yours or getting a used replacement unit, or trading it in as is somewhere. There are usually used ones on either eBay or Rancho Lexus used parts (do a Google search, you can call them). Then you need a good car audio shop to install it or do it yourself.
https://www.ebay.com/itm/12427886974...3ABFBMqs2d9qNg
I don't think you can operate the vehicle after removing that unit, too many systems are integrated into it but these threads may have more information.
https://www.clublexus.com/forums/rx-...-11-rx350.html
2014 Lexus
I also came across a Youtube video by Scotty Kilmer that showed how to make a simple computer bypass switch and operate the Air Conditioner manually..............He did it on a 2010 Honda,,,,,, ( www.youtube.com/watch?tv=0Foh6IF9Z5I )
I wonder if anybody has done anything similar successfully on a late model Lexus ??
I only need the Air to work......do not need the radio/CD.
Thank you again
Daspyda
02-26-16 10:16 AM
