Unable to reset TPMS warming - 2010 RX
During a drive, I had TPMS warning displayed. I pulled over, inflated one of my tires and continued the trip.
During the drive the warning stayed up. I found directions on how to reset it using the button in the foot well with the car on to the accessory power only (no engine).
I also inflated the tires to the appropriate pressure.
However, after pressing and holding the button, the TPMS warning continues to stay up. I noticed that the panel on which the reset button is located feels somewhat "loose" is it supposed to be that way? I wonder if the external button isn't touching the internal reset.
Any other issues that may preclude TPMS warning from resetting?
Can't be sure, but for a car of that age.... I'm gonna say the battery in the actual TPMS sensor is probably dead. While they do last a long time, they do go dead eventally,
Unfortunately, back then you can't see the pressures on the dashboard so hard to tell which one(s) are faulty. You'd have to go to dealer or some other place that has a scan tool.
Can you please state the exact warning statement [depending on the model/display].
The expected age of the sending battery in each tire is about 8-10 yrs. Once that battery depletes, you have to have it replaced and it requires removing the tire and rebalance etc. I just got one done at Costco a few weeks ago.
Salim
Salim
Salim
Salim
I don't remember exactly but it was around $75. Just give them a call and they will let you know over the phone. The only issue was that the sensors were in short supply and the first time they did not have any. Next time we were at Costco, I checked and they had some at hand, so I purchased one and made an appointment based on mutual convenience.
For my 450H, the TPMS light was on, as well as a message "communication error" [or something similar].
One of the signs before the actual fault popped up was, one of the tires was slow in conveying pressure info. I had 3 readings on display and after a bit of driving the 4th would show up.
Salim
PS: Again a phone conversation will confirm what Costco can do for you, even if the tires are purchased from someplace else.
Salim
Salim
Salim
It was indeed TPMS battery. Costco replaced all 4 for around $270. Keep in mind if you have Lexus or other stem covers, take them off. The mechanics threw mine out. They replaced them with the round green ones.
Whenever any of our vehicles go into a tire shop for any work (tire repair, new tires, etc.) I always remove and keep all metal valve stem caps and sleeves. Some tire techs are meticulous about returning your parts and some are not, so why run that risk.
Salim
PS: Compressed nitrogen at initial install is a bogus claim, as no where the ordinary air [which is predominantly Nitrogen] was evacuated. Essentially your tire has relatively more Nitrogen. The real culprit is the moisture in the compressed air [very few places have working moisture removal equipment in compressed air to fill tires. Advantage compressed Nitrogen.
I seem to remember that the RX (and maybe other models) had a recall related to the brake sensors? My warning light has been on so long I reverted to the time honored, traditional black piece of tape. On a Tundra, I replaced sensors (about two years ago) and they were ridiculously expensive. About $600 total installed. I would replace mine on the Lexus if they are under $300, as above.
The sensors are not as expensive as the total cost. In hind sight if I was smart, I would replace the senders when ever I replace tires in 7yr window. I replaced mine a year ago [9yrs in service] and should have replaced the senders.
Sensor + dismantling tire(s) + installing sensor + installing tire(s) + balance + programming
Salim
