External transmission cooler really needed?
user 538292 (07-10-22)
Started the car and let it run for about 5mins or so, just to make sure there were no leaks.
Waited until the next day and did a drain of the A/T pan, including the removal of the plastic check tube. There was over 2.5 litres that drained out.
I re-installed the check tube and drain plug and pumped in 3 litres of new Toyota ATF WS. Ran the engine until the A/T fluid hit 104F then removed the drain plug until the fluid was just trickling. Placed a new crush washer on the plug and re-installed to the specified torque.
All done!
So what I did is I put in about a litre of Toyota WS ATF after the radiator, A/T cooler and hoses were all replaced. I had no idea how much in total leaked out before when I saw it was leaking, and during the replacement of all the parts.
I re-installed the check tube and drain plug and pumped in 3 litres of new Toyota WS ATF. Ran the engine until the A/T fluid hit 104F then removed the drain plug until the fluid was just trickling. Placed a new crush washer on the plug and re-installed to the specified torque.
All done!
All done!
Willauflex
08-27-19 08:14 AM
