Towing capacity 2013 Rx 350
1st Gear
Hi: what is the max towing weight of my 2013 rx 350? I googled and get varied answers ranging from 1500 lbs to 3500 lbs. Thanks for your help!
asku4water (06-30-22)
When equipped with the Tow Prep coolers it is rated to tow 3500 lbs.
If not equipped with Tow Prep it was rated to tow 2000 lbs.
Simple way to check is to look forward through the wheel well liner on
the driver's side. There is a series of vent slots and if you see a aluminum
heat exchanger (radiator) then you have the Tow Prep Package. You can
also look and the lower front valance area and compare the Passenger side
and Driver side outer lower grille inserts. The Passenger side is a blank
"fake" grille on all models, the Drivers side will match if you do Not have Tow.
It will be slotted and open to pass air to the cooler if equipped with Tow Prep.
Both cars are good, but the NX feels small to me, with not enough room for the driver width-wise
Both RX and NX feels slow, but those vehicles are not for aggressive driving
johnnieade
RX - 3rd Gen (2010-2015)
04-30-19 07:07 AM
