Hello everyone! I wanted to ask for some help. I currently drive a 2015 RX 350. One day after getting tired of the "Maintenance Required" message on the display, I went ahead and reset the message using the odometer button method. However, after that, the standard MPG display in its place no longer is there.
Everything else about the car functions perfectly. There is no issue with the navigation system, bluetooth, lights, odometer, etc. In fact, whenever I adjust the brightness of the dashboard, the area where the MPG display would be lights up with the brightness information. It's just that the MPG display itself just doesn't show up anymore. It is quite literally the only thing that isn't functioning at all. For reference, please see the attached image. The MPG display would usually be in that area right above the line and where it says "OUTSIDE 43 F".
Any advice or tips would be greatly appreciated. Thanks for reading!
