Use RAV 4 OEM parts for RX
Would you guys know if I could use Toyota RAV 4 OEM parts for Lexus RX 2011? OEM Parts for Lexus are expensive. Would there be a way to confirm the fit? I called Toyota, but the guy would not want to verify if it fits. When I buy parts from RockAuto, many say for both Rav 4 and RX. What is your experience?
When you say "it" what are you referring to? Toyota and Lexus share some parts between models/years depends on the part.
Our cars share a lot more parts with a 2014-2019 Highlander than a RAV4. I'm interested in what parts you're looking at
Get the water pump from Toyota for a 2008-2015 Highlander with the 3.5 engine. No suspension parts from a RAV4 will fit our cars, they're on the wrong platform. 2008-2013 Highlander shares the front suspension from our cars, 2014-2023 Highlander for the rear suspension. I have Bilstein B6 on mine 2010-2013 Highlander fronts, 2014-2019 Highlander rears. Perfect fit and much better than what Toyota / Lexus has to offer in a strut or shock assembly. 2008-2009 Highlander front struts are not compatible with the newer driver's side front spring due to the spring perch being reversed on that side for 2010+ facelift models.
The water pump is the one that works on the 2GR-FE engine which is used by Toyota and Lexus in a lot of vehicles. For instance the RX350, ES350, Highlander and Sienna all use this engine. The water pump failed in my Sienna last Summer and it has the same 2GR-FE engine. I did not want to deal with trying to work in that tight space and had a used a local independent shop that installed a NAPA replacement water pump and said it had a better warranty than the Toyota one. It was 5 hours labor. They have to loosen some motor mounts to move the engine a bit to get at all the bolts and remove & replace the water pump.
The RX shares the front suspension (mostly) with the 2008-2013 Highlander.
The RX shares the rear suspension (mostly) with the 2014-2018 Highlander.
Some Online seller such as Rock Auto provide a cross reference for most parts that shows all the vehicles the part fits. There is box to click on each parts listing that has the info.
GrayES300
11-07-09 06:49 PM
