Question on AWD lock mode on 2021 RX350 F Sport
according to manual we activate this feature by press on the button, but the graphic on the button is kind of misleading. it has an "X" between the front and rear axles, doesn't that mean the opposite of applying torque to the rear axle like the manual says when we press it?
When you press the button, the same icon will appear on your gauge cluster in a solid orange. This just means that full AWD is engaged (great for off terrain). It will disengage once you reach over 30mph I think.
Lexspeed (07-27-23)
MLE1377 (10-20-23)
Today I switched from Normal mode to Sport on my 2021 RX350 Base Model while driving I felt as thou the steering wheel pulls to the right, so I stopped & switched back to Normal mode I didn't feel the pull to the right any longer . Would/What this situation possibly causing the steering wheel to act as it did or it could be something else.
If it was really pulling to the right, and not just an impression or feeling, there's a problem with the car. There's nothing about S or S+ that should pull the car in either direction. If it really is pulling off center on level road surface, I would start with verifying tire pressure on all four tires, them have the alignment and brakes checked.
ravenuer (10-04-23)
autotech13 (10-05-23)
harut2k
RX - 3rd Gen (2010-2015)
08-08-17 02:47 PM
