Tire psi read out showing ———
2016 RX350 with 103000 trouble free miles. I recently noticed that the tire psi on the dash is not reading anything. It just shows ———. Anyone else having this issue?
TIA
TIA
A TPM sensor may have died. If one goes out the whole system quits working. Your local tire store can check it for you.
I would love to see a constructive answer. I have the same problem after buying new tires. The vendor checked all of the tire module's batteries and entered the codes for each location into the OBD.
Read the manual - there is some initialization procedure I believe that may solve your problem. I've had the tires replaced on both of our Lexus cars and didn't have any issue so perhaps your vendor skipped a step.
TPMS was evaluated by two Lexus service centers and the tire retailer. There were no codes to deal with. Though the battery strength of all four modules were ok, all three servers recommended replacing all four TPMS sensors. Discount tire installed BH Sens sensors with complementary rotation and balancing. The system is fully operational.
The following 3 users liked this post by jfz219:
Anyone know how to disable the TPMS: I'm tired of having it fail at random times. When I bought my '17 RX 350 a few months ago, it had new tires and everything worked fine, Then it started giving me bad ---- info on all tires, then started, working once again. All tires have measured 32 psi.
I've seen several comments on how unreliable this system is, and I'm ready to disable it . Don't think the Owners manuals will tell you how to turn it OFF.
Any ideas?
Steve
Any ideas?
Steve
Any ideas?
Steve
Any ideas?
Steve
1. Take it to Lexus and have them disable the TPMS using the factory computer and the OBD II port. Texas does not require a functioning TPMS system.
2. Stick a piece of black tape over the area that displays the TPMS message on your dash.
I can think of 2 ways to fix it.
Any ideas?
Steve
Any ideas?
Steve
Typical sensor battery life is about 10 years. So a bit early for that to fail for a 2017.
Are they Original sensors ? (Silver Metal tube coming out of the rim)
