No washer fluid to rear wiper
With the car turned on (engine off) run the washer to see if you hear the washer motor running. If you can hear it then the hose is kinked/clogged or the nozzle is clogged. If you don't hear it, the fuse is blown or there is a problem with the pump motor. Let us know how you make out.
I should have RTFM. I tried a search in the pdf for it, but when I actually read the section on wiper operations I found the rear wiper washer is a push forward function on the wiper stick. Now I know how it works on Lexus vehicles.
A440 (11-15-23)
