The car has been adjusted to E85 and it operates well with short fuel trims. However, the long fuel trims require some fine-tuning as it’s still running a bit on the lean side. When at wide-open throttle (WOT) and cruising, the KCLV happily maintains a level of 33-34.
Brother, appreciate you. Recently purchased a 21. Been looking for a practical application of VF on a recent model. Best I’ve found (without contacting VF yet) is this tune package - https://vftuner.com/products/highlan...-fks-tune-pack
So you would actually need to create your own tune. VF tuner just sells some base maps that you can work with but they don't have one for the RX 350. I had to do a lot of data logging and testing to get the tune dialed in.
