Locked out of RX350, keys not working
I have a 2016 rx250. I started noticing recently that sometimes when I turn off my car and open the door, the chime will come on. When ever that happens, I would not be able to lock my car with my fob. There would be a long beep and a message on the dash saying "key fob not detected" and a "turn vehicle off" message even if the car is turned off. Today, I turned off my car and opened the door(no chime this time) and locked it with the door handle touch system. I went to try and unlock my car later and it would not unlock. The fob, physical key, and even the unlock button inside the car(we had to pry the door open a bit to get a stick in) did not work. I thought my car battery was bad but it was not the case. I even changed out the battery on the key fob and still nothing. The only way we got it to open was pulling the door handle on the inside of the car. After I drove it home, I tested the key fob and everything worked fine. We determined it must be some kind of electrical issue. Has anyone had any similar issues with their lexus? And any clues or idea to what could have happened. I do plan to take it to a shop to get it check out soon.
The next time it quits working, see if the tailgate will open and close. I suspect that the lock actuator or actuator sensor may be the problem. It's possible that some moisture got in there and over time caused some minor corrosion to the electrical contacts. This would explain why it works intermittently. If you are not a DIY person, you probably have a local locksmith that works on car locks. It would be a lot cheaper than the dealer.
leouk (07-29-24)
I assume you have only (1) key fob. All of my RX's came with (2). It would be a good way to eliminate the key fob having the issue.
Key Fobs can stop working, I had an Acura TL Fob that that had similar issues, and I started using my wife's until replacing it.
i agree with jcg that you should call a local locksmith, depending on where your located. we have a place nearby and he helped me with a similar issue and im sure he would be happy to answer any questions. it may be that it could be electrical and not immobilizer related at all so it wouldnt hurt to ask first. not sure what the rules are on posting phone numbers but the place is called nela locksmith and the website is here
Not an expert on this kind of stuff, but it sounds to me like the FOB battery was bad. I know it still didn't work after changing it, but I kind of think the FOB needed to be "paired" with the car again, which sounds like what happened. Glad it's ok now, let us know how you make out.
re: my app always shows Key Fob low, even after I replaced both batteries with Energizer ones. If I was to pull a battery out of 1 Fob and leave it out for a few hours, will it mess up the pairing with the car?
A suggestion, if your physical/manual key refuses to unlock the door, it may be in need of lubricant. My key refused to work for me or the AAA roadside tech, later I doused the lock opening with lubricant and it works fine now. The mechanical key operated feature is not connected to the battery and does not require battery power to operate the driver's door. It is purely mechanical. Please correct me if I'm not correct.
DenisR
RX - 3rd Gen (2010-2015)
14
05-12-24 07:09 AM
