Front brake discs are too hot
Hi there!
I have 2022 F Sport, and after 50k miles I started filling vibration during braking. Dealer found that front discs are bad and need to be replaced. I ordered new OEM discs and replaced them by myself. I also changed brake pads.
After that I noticed that discs are too hot after driving on highway (it does "pshhhhhh" when I apply water on disc). I changed pads back to old ones (had a guess that new ones doesn't fit or something) but it is still an issue.
Planning to order Brake calipers repair kit and do some work there, but not sure if it will help.
Any ideas on that?
Any ideas on that?
Well, discs do get hot after driving for a while.
For me it happens after regular trip, I'm not driving like Formula 1 pilot, so I think that this temperature of brake rotor is high. But if anyone else has the same - maybe this is normal temperature, that's why I'm asking here.
I usually did that for old cars: when you spit on brake rotor and it is hissing like water on frying pan = it means that rotor is overheated, and brakes need to be repaired.
PhxBill (05-20-24)
The following 3 users liked this post by IntrinoX:
Wow wow wow, hold it there.
The brakes do get hot when they are applied, i.e. the brake pads are forced to stop the rotating rotor. Any brake can be overheated. If you are going down a mountain or stopping from high speed often, like in a race, it's normal for them to get hot or even overhearted.
Regular driving on the highway should keep the rotors at ambient temperature, no friction should be applied while driving. If they are hot, chances are, your calipers bind, or you didn't install the springs on the pads correctly... I assume there is no bearing noise, that could also cause the hub and disk to get hot.
If you replaced the pads and rotors with OEM replacements then they should not be any hotter than before. You shouldn't be hitting them with water while they are got unless you would like to warp them? It's certainly possible your caliper slides pins need to be greased. This is something that you can count on the dealership doing as part of every brake job and is part of why they charge a lot for a job that seems like anyone could do themselves. If the caliper isn't able to slide freely then the brake pads could be sticking and dragging on the rotor at all times and that would cause it to get hot, and could be what warped your last set of rotors.
Hi there!
Any ideas on that?
Any ideas on that?
If you serviced your caliber pins and lubed them as well as cleaned at sliding surfaces and lubed them, in addition to new parts you should be good.
Normal for brakes to be hot after driving.
Not a good idea to splash them with water though. It will warp the rotors.
If your brake lines are old or damaged, they might be getting constricted and causing pressure to build up in the brake system. This can stop the calipers from releasing properly. I’d think about replacing the brake lines if they look worn out or damaged.
Hi there!
Any ideas on that?
Any ideas on that?
Gillie76
Suspension and Brakes
18
11-05-17 04:50 AM
masboy
08-01-15 08:40 PM
1WILLY1
10-12-12 09:35 AM
