Is it possible to change the oil and filter without ramps?
I’ve used oil extractors on boat engines, but cannot speak for their use on our Lexus engines. In general, though, I don’t choose to use an oil extractor if direct draining through the plug is reasonably convenient. Since getting under the RX is easy, why use an extractor that a) leaves a significant amount of dirty oil in the pan and b) runs the risk of damaging sensors or emission components?
ravenuer (07-07-24)
I glanced over your post and now note that you have a MityVac. May I ask whether you are using your MityVac for engine oil extraction, and if so, are you extracting the engine while level or on wheel ramps? Also, how much oil remains after oil extraction when you remove the engine oil drain plug? Thanks.
azncapcom
06-15-20 06:51 AM
