Cross-shopping the Volvo XC90 and Audi Q7 -- sell me on the RX
#76
But it's there if you need it, whether it's ideal or not. I having a minivan I wouldn't buy a minivan if I didn't have kids and only needed a third row every once and a while, but going forward I'm going to want a third row in any crossover/SUV I buy, which means Lexus doesn't have an option for me currently.
In that vein, unfortunately I wouldn't even consider the RX compared to an XC90.
#78
#79
I've said it until I'm blue in the face...they need a three row crossover in the lineup...
#80
You're comparing gross weight to curb weight lol. Gross weight is the weight of the vehicle fully loaded to spec.
The curb weight of the XC90 (First Edition gas model) is 4,627 lbs. The gross weight of the XC90 same spec is 6,060 lbs.
The curb weight of the RX AWD Gas is 4,387lbs and the gross weight is 5,864 lbs.
So the XC90 is 240 lbs heavier....not 1800 lbs!
The Volvo eats tires on average every 27,000 miles because of the negative camber of the vehicle, you get to spend nearly $1,000. I have no factual information/experience on if the RX eats tires, I suspect it does not? the OP asked about thoughts between the cars? I am giving experience take it for what you will and buy what you want, I dont care.
Resale value of the Volvo, again because I just experienced it was virtually nothing.
Good luck
#81
This style is for show not for true taste.
Will you put shining glasses everywhere in your home?
even you put true diamonds, that's still not good.
but unfortunately, those shining pieces are not diamonds, they are cheap glass level material.
Quality wise, after several months you will see scratches everywhere.
and the touch and feel of those material is filmy also a letdown
Buying Lexus is not only for reliability, but also for quality.
#82
like i said. Volvo put the shining cheap plastic everywhere.
To me, the problem is not just about the use of shiny vulnerable black plastic in the cabin but where those shiny plastic are.
From the picture, the Volvo XC90 interior panels appear to have high quality materials tastefully constructed. It has very clean layout. Sadly, when seeing in person, I was shocked that they use black shiny plastic in the switches where you have to touch them very often. Not to mention the average passengers are not as mindful as the owners and the detail-oriented owners will get a lot of frustration when giving a ride to passengers.
Why on earth did those Volvo interior designer think it is a good idea to put extremely scratch-prone black shiny plastics on steering wheel buttons, window switches, etc?
Those shiny black plastic buttons are common in some mainstream non-luxury brands.
Scratches, marring and fingerprints would probably be a common complaint in Volvo XC90 forum.
On the other hand, the interior materials in 4RX are consistently of high quality. Only a few areas where the material is a bit vulnerable -- the bottom centre console plastic is the same black with mild metallic accent used in 2014 3IS. I was surprised why this material is coming back as Lexus has already switched to more durable grey in 2015 3IS, NX and RC/RC-F.
Sometimes pictures don't do justice --- case in point --- reviews on the Internet have high praises about the interior material of the new BMW X1 but I find it pretty horrible when seeing it in person. Yes, it has high quality matte wood but somehow the whole dash looks cheap.
#83
Like I said, I dont care if the cars weigh exactly the same, multiple failing transmissions matter, the second time it wasnt under warranty.
Good luck
Good luck
As for tires, any vehicle with low profile tires is going to eat tires, including the Lexus.
#86
Shining cheap plastics...is more like the RX. (even then the RX has moved its material quality up as well).
Shining cheap plastics are found on th QX60, not on an RX or XC90. Too many assumptions
#87
Must be something the US miss out on then. All RX's in the UK come with a genuine leather dash.
Probably similiar to how you guys get the Nuluxe in the IS and we can't. Only real leather here in the UK apart from on the IS F-Sport standard seats which are cloth and synthetic leather and the CT which are mainly cloth until you upgrade
#88
#89
You posted information that was not correct...we corrected you. The fact that you had failing transmissions doesn't mean anything. This is a new generation Volvo. The first gen RX had a lot of problems with failing transmissions on AWD versions, but they made changes and moved on.
You can't dictate taste. I think the interior is very nice, you clearly don't and thats fine.
A tire's profile refers to the height of the sidewall. On a tire with an aspect ratio (profile) of 65, the sidewall's height is 65 percent of the tire's width. A normal tire is 60 or 65. Fifty and 45 would be considered low-profile and would have a shorter sidewall
Volvo XC90 does not come with a low profile tires, numerous replacements of 235/60-18 not low pro... Everyone is wrong once-n-a-while even you.
enjoy your XC
#90
Originally Posted by bootman
I guess Lexus considers that the GX.
235/55/19
275/45/20
275/40/21
275/35/22
The 4RX has standard 65 series tires and 55 series tires on the 20" wheels.
My point is, I would not expect significantly better tire life on the RX. They're front heavy, hard on tires too.
enjoy your XC
