Cargo Area Lighting
#76
i have the single sided ones. the color is much whiter then oem, but the light output is about the same. perhaps i'll give this one a try.
Considered the single sided LEDs but the brightness seemed less than half of the multi-sided ones I got. Maybe it was marketing hype? Color is around 5000k to 5500K when comparing them to other lights of known temperature. Interior lights seem to be 4000k perhaps? The old filament T10 I removed were very yellow 2700K in comparison. Got these.
JDM ASTAR Extremely Bright PX Chips 168 175 194 2825 W5W T10 LED Bulbs,Xenon White
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Here is a closeup pic of the light assembly. All 3 lights in back are the same. The OEM bulb is in the socket, and one bulb I removed is at the top of the frame to see the entire bulb.
#77
#78
I know this isn't cargo lightning related but does anyone know how to remove the rear DOME light clear panel? The "detailer" sprayed something near the light and now there is dried up water marks inside the clear light plastic piece .
Thanks!
Thanks!
#79
LED Cargo Light Module
Hi,
My wife picked up a 2020 Lexus RX350 Premium package in Canada. I guess it's either the 2020 or the upgraded package cause the bulbs to be upgraded to LED Modules (see pictures below).
But the brightness from the stock LED bulbs leaves a lot to be desired as the overall brightness level is like stock halogen. What modules do I have to get to upgrade these?
#80
Hi,
mirkee (03-10-20)
#81
Those look terrific, and bright. I assume it's a complete module and no need to remove the bulb from housing. Bulb and housing/lens come together? Can you give us a better link. I really want to get these. Stock lighting is really dim.
Thanks!
Thanks!
#82
#83
yes they do not need bulb replacement, just plug and play.
Link here!
Link here!
mirkee (03-22-20)
#85
Actually, I have a different idea. For those that have the resources (i.e. maintenance manuals / exploded views and part numbers) that can help.
Much appreciated!
- Can we please find the part numbers for the cargo lighting module part number on the 2016 to 2019 model? This is the one showing earlier in this thread with everyone posting LED bulb replacement.
- Can someone find the 2020 cargo lighting module and see if we can interchange them with the older 2016 to 2019 model?
Much appreciated!
#86
Much appreciated!
Much appreciated!
Now I need to find an online resource that is updated to include the 2020 model year to determine if the parts are interchangeable.
#88
cargo area bulb sizes?
Does anyone know what size bulbs are the 2 bulbs in the cargo area and the one on the rear hatch ? they seem excessively dim, and i want to put in some LED lights. Is the bulb on the rear hatch the same size?
#89
Thanks for combining moderators. I ended up getting four 194 led bulbs (three for the rx rear cargo and one for the ES trunk) from Canadian tire because I didn’t want to wait for an online order. And they were relatively cheap at 13 dollars each compared to Amazon.ca at 18 bucks each
https://www.canadiantire.ca/en/pdp/1...2906p.html#srp
I also did not put on the gray inside plastic cover as I felt it blocked out light and was unnecessary due to the cool running nature of these LEDs vs halogens.
#90
Interior Cargo lift light
Can someone direct me on where I can purchase an led bulb to replace the halogen bulb currently located on the inside of the hatch. Or is there some sort of complete module that already has the led bulb installed..
thank you
thank you
