RX F-sport with 20" and 22" wheels
Yeah, they put the wrong size tires on it. Looks horrible and probably rides much worse.
With the proper 22" wheels (not these in the pics), it will look great.
Corrado in the NX forum has 22s on his NX and it looks AWESOME.
I have to think it will look equally great o n RX.
Need to have the right size tires with a bit more meat for the best and proper look.
Of course noise and little less cushy ride, BUT 22s are really what should be on the car for the proper look.
definitely further sportifies the car.
Well the problem with the new RX is, the plastic trim above the tires. The wheel gap is going to look ridiculous no matter what you do, but using the wrong size tire (too small) will exacerbate the look. Hopefully @LXSalesman can post some more pictures once they get the new tires mounted.
The pursuit of F
Yeah, change the tires please since they are WAY too SMALL and wrongly sized. Taller tires would look better. OEM diameter on the RX for the 235/55/20s is 767mm while the 255/35/22 rubber you have is only 737mm, off by 30mm or well over an inch! The tires you need to put on are 265/40-series tires on the 22inch rims which will give a diameter of 771 mm. It's also 99.5% within the diameter of OEM which won't mess up the speedo and odometer readings.
