Anyone get Lexus to order the hitch kit?
Old 07-04-18, 02:49 PM
  #166
mspearl95
mspearl95's Avatar
Originally Posted by Scrutator
Thanks! That worked great. The only difference is the number of push-pins and bolts holding on both the left and right under covers- they must have changed it slightly between 2016 and 2017.
Old 07-04-18, 02:53 PM
  #167
mspearl95
mspearl95's Avatar
Originally Posted by gadgetman1
I’m not trying to be mean. I hope you got this for a REALLY good price, because it doesn’t look very professional in my opinion. Only the Lexus hitch requires cutting the bumper. Aftermarket hitches are designed around that & there is no cutting & they cost WAY less. Sorry to rain on your parade, but I’m just stating what I see.
I greatly prefer the look of the OEM hitch, because ti is tucked away and not very noticeable. I just wish Lexus would have designed a replacement bottom bumper trim that was molded around the hitch, instead of just getting one with a cutout.
Old 07-05-18, 07:55 AM
  #168
Hubs
Hubs's Avatar
Originally Posted by CharmCtyIS
The Curt hitch does not need a cut out. Designed for the RX. This is mine installed.
Can you show more pics of the install?
Old 07-12-18, 06:21 PM
  #169
dnkyle
dnkyle's Avatar
Where do I get the hitch for 350L? Ask the dealer not available yet.
Old 10-06-18, 09:06 PM
  #170
richard203
richard203's Avatar
Originally Posted by elimmigran
Went with factory hitch and related parts.
did u need to cut the under panel?
Old 10-06-18, 09:19 PM
  #171
elimmigran
elimmigran's Avatar
yep. It’s required
Old 10-07-18, 07:09 AM
  #172
toyotaman7
toyotaman7's Avatar
The complete kit includes the lower bumper piece with the cutout already there. No cutting in that case.
Old 10-07-18, 07:30 AM
  #173
elimmigran
elimmigran's Avatar
On my 450H F-Sport, a plastic piece underneath the car had to be cut.
Old 10-07-18, 08:53 AM
  #174
CharmCtyIS
CharmCtyIS's Avatar
Sorry I don't have more pictures. I'll try to remember to take some next time I'm using the car.
Old 10-07-18, 12:06 PM
  #175
richard203
richard203's Avatar
so I read that I ned to take off the bumper to install this? I thought the only thing I need is the lower part of the bumper and the hitch isn't it?
Old 10-07-18, 01:42 PM
  #176
mspearl95
mspearl95's Avatar
yes, you must take off the bumper skin, and remove the internal bumper, which gets replaced by the body of the hitch receiver. It is also necessary to have the bumper skin off the car to detach the bottom portion. All in all not too difficult to do.
Old 10-14-18, 04:47 PM
  #177
really
9th Gear
really's Avatar
Default Trailer hitch install
What's the best way to get a trailer hitch installed? Dealer would be $700 with hitch + ball + installation. UHaul quote is $250, but would that void any warranties?
Old 10-15-18, 06:47 AM
  #178
ravenuer
ravenuer's Avatar
No, that shouldn't have any effect on your warranty, IMO.
Old 10-15-18, 10:03 AM
  #179
chunktwo
chunktwo's Avatar
they would have to show that the uhaul installed hitch impacted the item you would be claiming warranty services on..
as an example - the dealer would have to demonstrate the hitch impacted the headlight having an issue to say the warranty was voided..
Old 10-16-18, 09:52 AM
  #180
Joelexus93
Joelexus93's Avatar
A few points:
1. I've had good luck with e-trailer.com on hitches. I've purchased and installed them myself. Very easy installations on most models with pre-drilled holes like Lexus. I checked and they have one for both the regular and the F-sport.
2. I have a 2018 RX350L. There is no hitch available for the extended body. I checked with both e-trailer and my dealer. It seems the spare tire positioning is lower on this body style, and so the regular RX350 hitch will not work. You have to question if there will ever be one that does, depending on what Toyota's real intentions are for the L body. Is it just a stop-gap model to fill a competitive need until they can come out that really competes with "true" 3-row SUVs?
3. I just ordered and installed the WeatherTech digital mats. I did the front mats and the rear cargo mat.They fit fine.
Hope it helps,
Joe
The following 2 users liked this post by Joelexus93:
dnkyle (10-17-18), really (10-16-18)
Quick Reply: Anyone get Lexus to order the hitch kit?
