Anyone get Lexus to order the hitch kit?
Old 12-08-20 | 03:43 PM
  #226
gadgetman1's Avatar
gadgetman1
Originally Posted by dibl
The suspension design tradeoffs between getting a cushy ride with one driver in the vehicle, and also handling 400 lb. of passengers plus 100 lb. of luggage, is a classic challenge for automobile design. It's pretty much impossible to get both on the same car. Having test driven a 2018 base model RX, and my F Sport, I think the F Sport has a stiffer suspension and, of course, a harsher ride with only me in the car. But I'd rather have that than a suspension that bottoms out with a full load. It's just a matter of personal taste.
I wouldn’t mind a little stiffer suspension. Cornering in my RX often feels like driving a bread truck that’s completely unsure on it’s feet. Don’t laugh, but I had an Oldsmobile Silhouette (Cadillac of minivans) that had the load leveling suspension in the back. That van was really up to the challenge! It handled good & road good for a van, could carry 7 people with ease & I could take the seats out & carry all kinds of heavy stuff & it didn’t blink an eye! Unfortunately, the 3.4 V-6 head gaskets were not good & it threw up all over itself internally (yuck). GM didn’t have the power train or safety worked out, but they sure knew what to do with the suspension.
Old 12-09-20 | 12:41 PM
  #227
bamalam's Avatar
bamalam
Originally Posted by gadgetman1
I wouldn’t say the springs are always sagging, they just won’t carry much of a load.
The springs on my non-F RX certainly are soft. It squats noticeably when I put it in gear. It's not an issue and I like the ride, but I can't recall driving a vehicle so softly sprung.
Old 12-10-20 | 07:54 AM
  #228
JCB460LS's Avatar
JCB460LS
10th Gear
Default 7 Pin Plug
Has anyone installed by dealer a 7 pin wiring harness for the tow hitch. We ave a camper ( 1580 GVW) but need a 7 pin for charging purposes.
Old 12-10-20 | 08:56 AM
  #229
toyotaman7's Avatar
toyotaman7
I have a converter to go from 4 pin to 7 pin for our pop up trailer, bit no active charge pin. If you want to charge your trailer battery through your cars alternator then you need to run a dedicated power Cable directly to the battery and install a fuse close to battery for it.
i did that on our last Venza, but Never used that. That was a waste. I change it at home and use only LED lights in the trailer if we camp somewhere non electric.
If you are thinking of powering your fridge while driving, you might overload the RX alternator and battery.
Old 12-10-20 | 11:56 AM
  #230
Verndog08's Avatar
Verndog08
I'm having a Curt 13282 installed tomorrow on my new to me 2017 RXh. I'm curious about this soft spring issue with towing. I don't tow a lot but there will be times I'm over 3,000 in my utility trailer and I'm wondering if there any progressive spring shock replacements for this vehicle? Progressive springs are nice as they don't hurt the soft unloaded ride as much and stiffen with increase in load.
Old 12-10-20 | 02:38 PM
  #231
gadgetman1's Avatar
gadgetman1
You will definitely notice the squat. It’s significant. I also have the Curt hitch. To my knowledge, there are no aftermarket parts that will remedy this. If you find something, please share it!
Verndog08 (12-11-20)
Old 12-10-20 | 02:48 PM
  #232
toyotaman7's Avatar
toyotaman7
I tow my loaded Trailer which weighs about 3000 or a bit more wit my F sport. No real issues with rear end sagging.
Old 12-10-20 | 02:56 PM
  #233
gadgetman1's Avatar
gadgetman1
Perhaps that’s the difference in the regular suspension vs. the F Sport’s. My regular gets squirrelly with 4 adults & luggage. The RX is a poorly designed SUV that’s never been improved. I’m looking to see how the new Genesis does in its first year. If it does well, I will be be seriously looking at them & leaving Lexus & their horrible old tech behind.
Old 12-11-20 | 09:40 AM
  #234
Verndog08's Avatar
Verndog08
The FSport suspension probably helps some, but also the factor of trailer setup / load and how much tongue weight and ball height you have will play a big role also.My trailer has fairly light tongue weight even when "properly" loaded so I'll see. That is only a few times per year I use that, bicycle rack is other main use so hopefully it will be acceptable.
Old 02-03-21 | 07:59 PM
  #235
johna1213's Avatar
johna1213
Default F-sport trailer hitch options??
I have not been able to find any trailer hitch options for a 2017 RX 350 F-sport. Has anyone done this?
Old 02-04-21 | 10:58 AM
  #236
NebulaGrey's Avatar
NebulaGrey
here is a non-oem... i was able to install this on my f-sport and it fits great.
https://www.etrailer.com/Trailer-Hit...leID=201743280
Old 02-18-21 | 10:16 PM
  #237
johna1213's Avatar
johna1213
What year RX F-sport do you have? Did you have to make any modifications? Can you post a picture? Just curious since the links says "excludes f-sport"
Old 02-18-21 | 10:40 PM
  #238
NebulaGrey's Avatar
NebulaGrey
2017. No mods. Bolt on. Didnt have to cut anything and it doesn’t rub anything either.
Old 02-27-21 | 03:37 PM
  #239
gadgetman1's Avatar
gadgetman1
I can assure you that tow package or not, the RX is a miserable tow vehicle! Don’t waste your time or money.
Old 02-27-21 | 03:39 PM
  #240
bmcinroy's Avatar
bmcinroy
I can assure you that two package or not, the RX is a miserable tow vehicle! Don’t waste your time or money.
:-) well we’re hoping to tow a small pop up trailer (only 1k lbs) so not worried about doing it in style or not - just getting it to campground, and we already have the RX so just trying to make it work... if I had the choice it woulda been a jeep for the towing
