Anyone get Lexus to order the hitch kit?
#317
#318
450h
https://www.etrailer.com/Trailer-Hit...leID=202144164
350
https://www.etrailer.com/Trailer-Hit...leID=202144163
#320
Check out this website, it lists both styles & talks about moving the exhaust hanger. Not available for F Sport.
450h
350
450h
350
#322
From one of my posts:
This is what I bought for my 2020 RX450h: CURT 13282 on Amazon
I think this one fits if yours is an RX350: CURT 13272 on Amazon
Installation took about 1 hr. I needed help from my wife for about 10 minutes to lift the heavy beast to the location.
#323
I think you "'ve missed something."
I actually bought the 13272 first. It didn't fit right. I returned it and bought the 13282. Worked great for my 2020 RX450h FSport.
#324
#325
#326
Did you consider putting the damper back on? Just spoke with a retailer that suggested the damper could be re-mounted with the hitch on first followed by the damper. I believe the bolts would be long enough. Thoughts?
#327
But then what was the point! The damper would be just dead weigh with the hitch installed.
The length of the bolts was not the issue. If you look at the photo of the hitch and the photo of the damper installed, you know why you can't have both.
Has "the retailer" you talked to actually done it him/herself, or does (s)he at least have a photo of it? There's simple not enough room.
(I copied the photo of the hitch from Amazon, and the photo of the damper from this post).
#328
I did think about it.
#329
I get what you're saying. A solid metal bar across the same points as the damper kinda defeats the purpose of re-installing the damper. The retailer is a trailer shop. Apparently they haven't done many of these, so I don't think Ill be going there.
Mine is not a hybrid, so the hitch is slightly different. My hesitancy is 3 fold; the dealer says I shouldn't do it, likely because of the damper. Secondly, I really don't want to cut anything on the bumper cover. Thirdly, none of the manufacturers actually list their current hitches for the 2020/2021 model year FSports. I get how you and others have installed yours, but that little voice in the back of my mind is saying wait a bit.
#330
But the points still are (1) the damper would do nothing whatsoever, and (2) it's difficult, if not impossible, to mount it with the hitch.
