Touch Free Rear Door Issues
Old 07-11-18, 11:19 AM
  #181
mikemu30
mikemu30's Avatar
Received 2,551 Likes on 1,819 Posts
We are all getting oh so spoiled by these gizmos.
Old 08-19-18, 12:35 PM
  #182
deusex
deusex's Avatar
Quickest way to open the lift gate without remote is to lay your fingers on the gate while rest of your hand is close to the blue lexus emblem.
Old 08-23-18, 06:06 PM
  #183
Elation
Elation's Avatar
It used to work part time and now it doesn't work at all.
It just beeps, once then two short ones.
It's faster to just put everything down and open with hand.
Today I had a box in one hand, planter in the other, placed my shoulder near the emblem, nothing.... spun around make sure the pocket with the key is facing the gate, got close to the emblem once again...beep..beep...nothing..
Put everything down, got the key fob out. Placed it right in front of the emblem...nothing.
I probably looked pretty stupid doing all that lol..
Old 08-24-18, 06:00 AM
  #184
ravenuer
ravenuer's Avatar
The instructions say to use your hand, not any other body part. I had trouble with mine in the beginning, now I seem to have the knack.....place palm of my hand over the top half of the emblem, an inch or so from the surface. Takes about 2 seconds or so and it opens.
Also, make sure the option is turned on!
Old 08-24-18, 06:15 AM
  #185
Elation
Elation's Avatar
Use your palm?
So one of your hands need to be free to operate this? LOL
it used to work when I lean towards with my shoulder.
The main purpose of this function is to open the gate when your hands are full.
I guess That’s why Lexus calls it a Touch-free door. Not a Hands free door.
Your have to use your hand, but don’t need to touch
Old 08-24-18, 06:23 AM
  #186
jim256
jim256's Avatar
Mine works just fine with an elbow when hands are full. Hover slightly above. There's always the button above the license plate.
Old 08-24-18, 06:43 AM
  #187
ravenuer
ravenuer's Avatar
Use your palm?
I just went by the instructions, never tried using anything else. I will have to give it a shot!
Old 08-24-18, 06:17 PM
  #188
GSFRX350
GSFRX350's Avatar
I use my arm, no problem.
Old 10-16-18, 01:33 PM
  #189
golferjack
golferjack's Avatar
Default Touch free rear door lock
I have the touch free rear door lock, where you are supposed to just wave your hand over the Lexus emblem and the door will unlock and open. It rarely works, I see from the manual you can have the dealer adjust the sensitivity to a higher setting (I guess Lexus feels that owners are not quite smart enough to have it as an owner option). Has anyone else had difficulty with the touch free rear door? The side doors work great without touching them.
Old 10-17-18, 04:06 AM
  #190
JSracer
JSracer's Avatar
you don't wave your hand. thats the issue
try say 6" away, hand sideways, over the top of the logo, not the bottom to see if that works.
if the doors unlock, but the gate doesn't open, that is not a feature, thats an aborted open of the gate.
its super easy once you get the idea how it works.
golferjack (10-20-18)
Old 10-17-18, 06:48 AM
  #191
ravenuer
ravenuer's Avatar
It took me a while to get the hang of it, but now it works every time.
Old 10-18-18, 05:24 AM
  #192
Coachdad
Coachdad's Avatar
This is the way to open the rear door using your elbow..
Here are a few other things to know about the rear door. Like don't wave your hand...
The following 2 users liked this post by Coachdad:
CharmCtyIS (10-20-18), golferjack (10-20-18)
Old 10-19-18, 09:11 PM
  #193
GSFRX350
GSFRX350's Avatar
Often use my arm to open rear door.
Also while the door is opening or closing you can touch the emblem and the the door's movement will stop instantly - the best way to stop it quickly if it's going to hit something.
Old 03-09-19, 12:42 PM
  #194
brfitzp
brfitzp's Avatar
Default Trunk emblem sensor broken
recently purchased a 2016 rx350 and the trunk emblem sensor seems to work 10% of the time. I brought it to the dealer, they got it to work once and every other try failed. Has anyone had this issue? Was Lexus able to resolve it?
Old 03-09-19, 01:37 PM
  #195
c3uo
c3uo's Avatar
I noticed in Techsream you can increase the sensitivity under "Customize". Maybe ask your dealer to make the emblem sensor more responsive.
Quick Reply: Touch Free Rear Door Issues
