Hesitation problem at various speeds (TSB info post #159)
#196
Actually noticed something weird with my cruise control and not sure if its related to the transmission issue in this thread. On occasion, when i hit the steering column stalk to raise the cruise control speed, the transmission will downshift and stay in that lower gear until i manually turn off the cruise control. It will not upshift itself. Also, if i'm going up a hill and the transmission downshift and i go over the hill it still stays in the lower gear and will not upshift. Anybody else have t his issue with the cruise control?
#197
You should ask your dealer that they did a hard flash reset before overwrite. They can't just do overwrite. If you do that it will make things worst.
#198
Honestly after driving it for a couple of days it feels exactly the same. Who knows, maybe mine already had that
version software. I was really hoping for some improvement.
#199
Service manager said the TCM was wiped clean now it would have to learn all my driving habits all over again .
tomtom74 (02-15-17)
#202
This TSB is not available in Canada...Apparently they are not aware of any problems.
So I called Lexus Canada and they contacted the dealer to have the shifting checked. They are going to run some tests and work with the Tech team to see if there is something they can do about the hesitation and jerky ride. They are aware that there is a TSB for vehicles delivered to the US.
For now, Canadian delivered vehicles...there is no fix.
#203
#204
Well I got my RX back this afternoon. 2016 RX350 F sport 3. I live in Canada and had discussions with Lexus Canada about the TSB that is for US vehicles only. I must say that they were very willing to work with me and get their technical team involved. The car was at the dealer for two days while they performed tests, and obtained the US TSB from Lexus USA.
Although the TSB is for US vehicles only they did something to the ECU that seems to have fixed the transmission. They said they did not do the TSB from Lexus USA but did change how the transmission acts. They would not tell me exactly what they did, but I am not sure the Service advisor would know...no offense to him. I did have a discussion with the mechanic yesterday before they did the change and he said he was waiting for a download from Lexus Canada.
I will head back next week to try and get more info from the mechanic. Stand by for updates. I am also going to connect with my case manager at Lexus Canada and give them my feedback.
Before when you would come to an "almost stop" and hit the gas the lag and or some gear would be slow to react. Same going around a typical neighbourhood turn, it seemed the car didn't know what gear it was supposed to be in, bog down, drop a gear and then go.
In my short time with the car now, none of those issues exist. In fact it seems to be ready for acceleration immediately. The RPMs at various speeds are the same as before. Still goes into 5th at under 50 KPH and 120 KPH RPM's a hair under 2K
The RX seems more engaged than before...is that makes any sense.
I'll keep you Canadians posted as I feel your frustration.
#206
I got the TSB serviced on Saturday and there is a big difference. I put about 150 miles on the RX this weekend. The gas petal seems a little more sensitive to me and there is no hesitation at all.
#207
Acceleration Hesitation
I found a solution to my hesitation problem. I started using 92 or higher octane gasoline. I have not had a problem since. Of course now it will cost more to operate. The droning problem still persists. Hope this helps you frustrated RX owners.
#208
Sounds like there is a TSB for it.
#209
I had the TSB. done but it not help my issue at all, in fact it might have made it worse.
I didn't really have hesitation to begin with. My issue is on normal acceleration, the car
will shift into 4th or 5th gear and the RPMs will drop way down to 1200 and I get a
considerable amout of drone and vibration until I step on the accelerator and it
downshifts. This Is so annoying cant belive this is a $55k Lexus. One of the worse vehicles
I have owned. I cringe everytime I see those Lexus commercials saying "experience amazing"
Yeah Im amazed someone hasnt drivin one of these through a dealership window.
#210
Lexus advertises that the RX has an 8 speed transmission but has anyone noticed that it never/rarely uses gears 1-3? If you switch to "S" while at a stop, the car is always in 4th.
It also seems odd that the advertised 295hp also arrives at the redline. Most cars give you a couple hundred RPMs after max HP to redline.
