Hesitation problem at various speeds (TSB info post #159)
Old 11-25-18, 09:49 AM
  #916
bodis
bodis's Avatar
yes, my wife also drives it...
Old 11-26-18, 01:17 PM
  #917
GSFRX350
GSFRX350's Avatar
My opinion is if there's two or more drivers who regularly drive the car the transmission, with its learning function, is constantly learning different driving styles. So if one person drives it hard, the other drives it gently it's trying to adjust and "getting confused". That's just my opinion - but then you said you had a 2016 which didn't have the issue, so that may have blown my theory out of the water. Did both of you drive the 2016 as well. Have you had the ECU reset to get it back to factory and start the learning afresh.
Old 11-26-18, 01:25 PM
  #918
rxtimes2
rxtimes2's Avatar
I am pretty sure that 4th-Gen RX does not have an adaptive transmission, so no learning. If you have any info, or a manual reference on the adaptive transmission in our vehicles , I would love to have it.
bodis (11-26-18)
  #919
bodis
bodis's Avatar
thanks, i'll try the reset
Old 11-26-18, 04:01 PM
  #920
GSFRX350
GSFRX350's Avatar
Maybe different models have/don't have but mine's Australian RX 350 F-Sport 2016.
https://www.clublexus.com/forums/rx-...-question.html
Here's a screenshot from the US manual about the AI Shift (Artificial Intelligence Shift) as Toyota/Lexus call it.
rxtimes2 (11-26-18)
Old 01-07-19, 09:59 AM
  #921
dunyamunya
dunyamunya's Avatar
Default Transmission Reset
I have read a few posts about transmission reset and only found one way to reset transmission in RX350 - disconnect the battery for a couple of minutes. I saw several sites mentioning the removal of EFI fuse for 30 seconds to do the same, but did not see any notes of it here. Is it possible to reset transmission that way on 4th gen RX?
Old 01-07-19, 02:42 PM
  #922
mikemu30
mikemu30's Avatar
Received 2,519 Likes on 1,799 Posts
Why do you feel the need to do this?
Old 01-08-19, 06:28 AM
  #923
dunyamunya
dunyamunya's Avatar
There are times when transmission hesitates and gas usage is low. Wanted to reset and see if there is any difference. I have seen where, for example, BMW had 20 m/g usage before reset and 24 after.
Old 01-08-19, 07:20 AM
  #924
Cocal
Cocal's Avatar
Not likely! MPG is directly related to performance, the best way to reset the transmission to improve MPG is your right foot.
Old 01-08-19, 04:20 PM
  #925
GSFRX350
GSFRX350's Avatar
I have read a thread on here somewhere about resetting the tranny by removing the correct fuses, two I think. Keep searching around the forum and hopefully you should come across it. My car was a used one. 18,000 km, long story but my transmission was messed up, had it reset by the dealer and made a world of difference.
Old 01-08-19, 05:06 PM
  #926
dunyamunya
dunyamunya's Avatar
This is what I'm trying to figure out, but nothing in rx 4th gen posts. Previous years, yes, but not current.
Old 01-08-19, 08:07 PM
  #927
GSFRX350
GSFRX350's Avatar
Sorry - this is what I read but as you say not 4th Gen, although I suspect it would be the same procedure.
https://www.clublexus.com/how-tos/a/...our-ecu-363500
Old 01-08-19, 08:38 PM
  #928
dunyamunya
dunyamunya's Avatar
Yap, that's the post I saw, but wanted to post here to make sure same procedure applies to 4th gen RX. I guess the only way to find out is to try...
Old 01-09-19, 05:25 AM
  #929
tommytqt
tommytqt's Avatar
I hate this so much. It happens all the time when the car is still cold but i have to leave right away.
Old 01-09-19, 09:36 AM
  #930
Machine13
Machine13's Avatar
It's my understanding that Lexus vehicles do not have adaptive transmissions. They do not learn driving habits therefore there is nothing to reset.
There apparently have been some BMW (and Benz) models that do have adaptive transmissions. But those models seem to only adapt the transmission's shifting pattern based on the last 20 or so shifts. So, it's more of a real-time adaptation in racing situations.
Or are you talking about something other than adaptive transmissions?
Is there any information from the manufacturer that Lexus models have adaptive transmissions?
Quick Reply: Hesitation problem at various speeds (TSB info post #159)
