Remote start with just the remote!!
#481
Yes, we had the same thing on the GX and for that reason I never used it. Seat heaters and coolers work pretty good and a few minutes of inconvenience isn't the end of the world. Lexus didn't think this feature through in my opinion.
#482
#483
Remote start issue / bug?
2020 rx 350 - Last night I had a very weird issue with the car. Tried to remote start it using the fob 3x lock sequence. At first it didn't start at all no matter what I did. Then at some point it started.
A few minutes later we went to the car, opened the doors, engine kept running. I've hit start+brake inside the car and that was it. Engine stopped and could be restarted no matter what I tried.
Dash illuminated but it refused to crank. The only weird thing was that the steering wheel remained locked. After trying to lock/unlock, remote start, regular start, it just didn't work, so I disconnected the battery for a few seconds.
After that the car started normally and drove without any issues. Remote start also works as expected for now and so far it kills the engine on door unlock as it should.
Did anyone have this happen? What is going on?
#484
#485
Can anyone confirm if you can or cannot remotely start your car with the key fob AFTER your subscription ends (and you do not renew it)? I have a 2022...
I've seen a lot of "I can" and "I can't" in this long post... wondering what final verdict would be for a 2022.
Oldsig (06-18-24)
#488
My 2020 will remote start after subscription. Press lock three times and hold on the last.
Oldsig (06-18-24)
#489
Remote Start after subscription ends.
My 2020 RX350 remote start works fine, from the key fob, after my subscription ended and still works(although I SELDOM use it)
Oldsig (06-18-24)
