Side Door courtesy shadow ghost LED upgrade
#151
Here are the ones I have. Whatever ones you get make sure they are 5 watts at least.
https://www.amazon.com/URSTOUD-Court...2950788&sr=8-4
#152
I've bought it from ALIEXPRESS and it's looking so cool
#153
I just installed the ghost light projectors, bought them off of Amazon. Easy to install and they look fancier than the stock light. Time will tell how they last! Anyhow, there’s two “tricks” to installing them. The first is prying out the old lights. I used a box cutter to slip in between the old clear housing and the door, then pry out. Only one side can come out (the side opposite the connector) so you can look at the new light to see which side comes out first. The second trick is figuring out how to remove the connector. The push tab to release the connector is outside the housing, just over the incoming wires. Push inwards on the tab (towards the wires) and the connector slides right out. Once I figured this out, total install time was less than 10 minutes. I’m not sure how well the new housing “locks” the connector in place so if a light quits working in the future that might be something to check.
#155
The factory lens is plastic. I’ve never seen a glass lens on any vehicle. I changed out my front door lights in 2017 or 2018 (with plastic) & they have been great ever since.
#157
Did you get plain lights or the logo projectors? I'd like to have lights with a higher color temperature, but don't care for the logo projection. I haven't been able to find them, though. Thanks for the install tips, BTW.
#158
#159
Are we talking about the projector beam that shines to the ground? I have went thru numerous ghost lights and the cheap ones with the plastic lens will look like **** over time. The glass lens one projects a nice bright and crisps image. But you use whatever you want ! I am just giving my recommendation
#160
