Illuminated Door Sills and Dash Cam
GoldenYear (06-29-23)
#228
Yes, I have one too and it has been perfect for the last few years. I notice on the new Rav hybrid there is an option for a factory installed camera, and it is about time that manufactures install cameras just like they finally now install navigation systems.
Quantum501 (07-14-23)
#230
For me getting under the dash to access the fuse box to do the taps was the hardest part.
Good luck and enjoy.
#231
I don't know if you saw my install posts but I used a zip tie and then "lubed up" the cables with windex (someone suggested this online in a video) and it worked well.
I had to use a long stick and it did the trick. It was still hard to insert the head of the cable through.
I've tried both sides and the left side was successful.
AZJowett (07-25-23)
RaiderHawk (07-30-23)
#234
#236
Even if the installer put the tint on the frit, cutting through the tint over the frit where you want it to adhere might work. Even if removal of the camera in the future removed the tint, you' have a natural break at the cut lines that would stop it from peeling from more of the window.
I am curious, though, why you wanted to tint the rear glass. It's quite dark from the factory.
#237
There is a ~ 1/2" band of frit at the top of the hatch glass. Did the installer install tint over the frit? If not, I'd mount the camera on the frit. It might need a short extension to get in the right position; you'd have to play with this.
You do make a good point about the frit, but it is not doable.
#239
this is plug and play. for front cam and look oem
code is Lexus3672
