Illuminated Door Sills and Dash Cam
Old 01-26-18, 07:13 AM
  #91
mssca
mssca's Avatar
Hi kess,
It is a paid option that can be added to any package. But you can buy the OEM cheap from eBay and install it yourself. I don't have these on my 2017 RX Executive model right now and I am going to do it myself.
Old 01-26-18, 03:10 PM
  #92
DaytonaV
DaytonaV's Avatar
$120
https://www.ebay.com/itm/Lexus-OEM-F...VXFkeQ&vxp=mtr
Old 01-26-18, 11:09 PM
  #93
kss
kss's Avatar
thanks for the info. If someone installs the illuminated door sill themselves and they are genuine Lexus parts, if there is an issue, any chance they will void the warranty? Reason i'm asking is that in my last RX350, i had a radar detector and laser jammer hard wired. About two years later i had problems with the sound system (DVD, Satellite, radio stations and iPod, would suddenly switch on their own and cycle between AM/FM/DVD, depending on what was being used). this usually occurred when we hit a bump - though not always. When i took it to Lexus, they said their diagnostic shows that there was work done on the car, so they couldn't fix anything even if they figured out what the cause was. In my mind it didn't make any sense that two years later an issue would come up with the sound system, because of the hard wiring of the radar detector. It also pissed me off, because it made having an extended warranty useless. THat's why as appealing and simple the mirror tap for a radar looks, i've decided to just use the lighter plug.
I don't want to be in the same situation again, if i install the door sill on my own and later have other electronic issues.
Old 01-26-18, 11:12 PM
  #94
kss
kss's Avatar
Originally Posted by Jagnut
Today I had the Lexus dash cam installed by the dealer and also installed the puddled door lights and the illuminated sils.
cheers.
how much did they charge?
Old 01-27-18, 06:02 AM
  #95
SCRXOwner
SCRXOwner's Avatar
The door sills are pre-wired so it is plug and play. It should not be a warranty issue. Lexus sells both Ghost Lights and illuminated door sills.
Old 01-27-18, 08:29 PM
  #96
lexnewbi
lexnewbi's Avatar
All you are doing is connecting an LED to the existing wire. At worst, all you can do is short the cable and blow the fuse.
In in your previous car, hitting a bump and causing issue sounds like a loose connection or a cable loose in the connector.
Old 01-28-18, 05:36 AM
  #97
aznkorboi
aznkorboi's Avatar
so what dash cams are you guys using and recommend??
Old 01-28-18, 11:08 AM
  #98
Milkshaker
10th Gear
Milkshaker's Avatar
blackvue 750 2 camera system
https://www.clublexus.com/forums/rx-...lp-needed.html
Old 02-01-18, 07:05 PM
  #99
DaytonaV
DaytonaV's Avatar
the door sills is like a 5min job to r&r. if you have any doubts voiding warranty when going to the dealer, just take them out and put the orig back in. i highly doubt these would cause any warranty issue as they are OEM. but to be safe, you can just take them out.
  #100
aznkorboi
aznkorboi's Avatar
They came out with a cool dash cam
https://owlcam.com/
Old 02-02-18, 06:49 PM
  #101
Googs
Googs's Avatar
https://owlcam.com/
$300 - No thanks!
Old 03-07-18, 08:59 AM
  #102
javapro
javapro's Avatar
Originally Posted by randomwalk
Thanks for posting the info. Got a white light set for $135 shipped from a Lexus dealership. Installation took less than 2 minutes for both side. Looks great at night.
Where did you get them for $135?
Old 03-07-18, 06:17 PM
  #103
DaytonaV
DaytonaV's Avatar
sorry, it appears that the price was raised from $120 --> $244
https://www.ebay.com/itm/331835600067?rmvSB=true
Old 03-07-18, 06:20 PM
  #104
DaytonaV
DaytonaV's Avatar
What's the part number for 2018 RX 450h door ghost lights? Where to get the OEM version? I don't see these listed on Lexus's official accessories site at all.
https://www.ebay.com/itm/Lexus-RX450....c100005.m1851
Old 03-08-18, 03:17 AM
  #105
javapro
javapro's Avatar
I was asking about the door puddle lights that project the Lexus logo onto the floor.
Quick Reply: Illuminated Door Sills and Dash Cam
