Bought a set of illuminated door sills for our new 2018 RX 350.
Literally took about 1 minute per side to install.
Look and function great.
Highly recommended!
I just installed a set too this morning for our 2108 RX350. It took about 5 minutes each side to remove the old trim and install the illuminated trim because I checked and rechecked everything to make sure everything was done right and fitted properly. The "hardest" part was popping the old trim loose and snapping the new illuminated trim on to make sure everything lined up. No mechanical skills required for this job. I purchased the set from MyLparts.com for $234 ($260 list minus 10% discount for CL members and free shipping for items over $150) and no sales tax for outside California. Very happy with the illuminated sills and MyLparts. Illunimated door sill comes in either Black or Beige (dark brown).
7) Connect the Male Mini-B connector from the Hardwire to the Female Mini-B connector from the extension wire. Determine how much slack you need from the extension wire to connect to your dashcam. Once you've done this, hide the wires by pushing the wires into the gap between the windshield and headliner. You're going to run the wire from the headliner to the gap between the headliner and A-Pillar, then hide the wires in the weather strip down to the footwell. Be careful when hiding the wires between the headliner and A-Pillar. I used my fingers to push the wires in. Notice that your airbag is in the A-Pillar.
What is going to happen if the side curtain airbag was to deploy? I think it would be safer to go down to the speaker and then cross the A-pillar with the wire. Ideally I would try to get the power from the rear mirror and completely avoid crossing airbags with wires.
anyone notice a difference in color of their LED door sill? Or did I just happen to order the wrong part. It’s described as black, but it clearly doesn’t match.
Has anyone installed a dash cam that gets power from the overhead unit that controls the moon roof and interior lighting? I saw a video online where they tapped into a harness in that module vs running a cable down to tap the interior fuse box. Looking for a basic unit with an easy install.
Installed the door sills last night. Literally took 5 minutes. My only concern was pulling up on the "old" sills making sure not to bend them, which in turn could potentially crease the steel and make them look terrible.
Purchased from Carson Toyota (Luis Salazar). $82 plus shipping. Not bad. I seem to remember the sills costing $300-400 when we got the same parts for the 3rd gen RX (2010 model).
Carson shows them for $240. Can you send a link? I'll buy them also if its $82!
