Reverse lights LED upgrade
#76
On ebay: LASFIT T15 LED Reverse Backup Light for Toyota Honda Lexus 6000K White 921 912( 323040083398 )
#77
#81
No and there’s no instruction needed. On the inside of the tailgate there’s two square pieces pry them out without breaking them. Pry a little at a time on all sides until you figure out which is the side your supposed to pull. Reach in twist the bulb socket, pull out the entire bulb. Pull it out of the socket, push in the new led bulb. If you use cheap bulbs they might be directional, so once you have them both in have someone press on the brake pedal and put her in reverse. If they both light up your good if not turn the bulb as the polarity is off. Better bulbs now aren’t polarity sensitive and work both ways. Once your all good twist the sockets back into place and replace the carpeted cover carefully. Close the trunk and test that the lights are both still working. Now stand back and admire your new cool white lights.
#82
#83
Upgraded
Made the back-up lights upgrade with the above. Waiting on night to check out final result. 5 min UPDATE/change.
nbailz (08-08-19)
#85
#86
I was just wondering bc mine does not have the triple beam LED headlights and I thought only the ones with triple beams come with full LED's all around.
Does your have the triple beam LED headlights?
#88
Today I replaced all turn signals, reverse lights and cargo lights with the LED bulbs:
Front turn signals - 7443-AHP28-T-2PK: Amber x2
Rear turn signals - 7440-AHP28-T-2PK: Amber x2
Reverse lights - 921-WHP10-TL: Cool White x2
Cargo lights(you need 3 of them bc there is 1 in the hatch itself) - 194-WHP6: Cool White x2 but need 3
Got them from superbrightLED and I bought the brightest ones
Here are some pics and videos
The following 3 users liked this post by bibika027:
#89
Reverse lights LED upgrade, Caution; (No more sound from the radio).
with these LED reverse lights from Aliexpress, https://www.aliexpress.com/item/4000479198888.html
dab reception is disturbed when reversing. (No more sound from the radio).
bibika027 (04-17-21)
