Reverse lights LED upgrade
#94
I personally really like VLEDs. They have a nice warranty. And they are quality LEDS. Another nice thing is they aren't huge profile and they can fit in smaller spots of the headlights, where a longer bulb normally doesn't get reflected correctly. I've used VLEDs for over ten years now and the ones they have now so far are my favorite style. I actually just ordered some for mt CT that I just got.
-Nigel
-Nigel
#96
my 2022 had incandescent back up bulbs.i remove those ancient relics and threw them as far as i could ( not really, but i wanted to). I replaced them with a set of LED bulbs i got off Amazon. They are a whiter light and a noticeably brighter. Who knows which brand is best. I doubt anyone has tried them all, and there are many to choose from.
#97
#99
with these LED reverse lights from Aliexpress, https://www.aliexpress.com/item/4000479198888.html
dab reception is disturbed when reversing. (No more sound from the radio).
#100
The LED lights emit too much electromagnetic radiation. If they are connected to the same bandwidth as other electrical devices, it will cause interference. It's also possible that the LED lights are interfering with the radio via the wiring.
#101
So on a 2022 I assume many of you have replaced some or all you can replace the bulbs even tho they already be LED in order to get brighter bulbs. None were LED on my Highlander, but I replaced all interior lights and back up lights. Has anyone done this and have a list of the ones they used and where you got them? Im sure there are several 921 size back up bulbs for instance.
#102
Good luck with that conception of basic physics.
lexnewbi (01-20-23)
#103
OK Just for clarification... My RX is a 2022 450h.... It DOES have LED back up lights already.. Upon removing said cover in the back, I cant even see where they are. PLUS in the manual instructions it says if listed bulbs are LED to have dealer change it.. Why is that and have any on here changed their back up LEDs to a BRIGHTER LED? If so where is the darn thing? Is it not a normal looking bulb?
#104
Most electromagnetic radiation or interference (EMI) is produced by badly designed high power circuits and board layouts with improper shielding that take alternating current (AC) signals and convert to DC. Also long cables with high frequency signals and improper shielding can leak electromagnetic signals. Electromagnetic radiation is caused by alternating currents in a circuit. So most circuits that work at high frequencies can generate it. Careful design, layout, and shielding of circuits can greatly minimize their EMI. In short anything running from AC sources, having a clocked frequency, or transmitting a signal (phone, radio, Bluetooth), can generate EMI. Wires long enough, in relation to the frequency of operation, and improperly shielded, can act as antenna and pick up this EMI signal and interfere with the signal that is currently transmitted by the wires.
LED are driven by direct current (DC) circuits or constant current. High power LED connected to alternating current (AC) sources need a driver circuits to convert the AC current to DC current to drive the LED. LED brightness also is controlled by quickly turning the current ON for a period of time and then OFF for the rest of the period. This is called pulse width modulation (PWM). You can see this effect by filming LED lights with a fast rate video camera. The video will show the LED lights blinking, but to our relatively slow eyes, they look on all the time..
Some really cheap and badly designed LED light bulbs that plugged into standard AC socket bulbs in a home were notorious for generating EMI and feeding noise back to other circuits sharing the same power supply wires. This injecting noise in the power supply is also typical of badly designed switching power circuits.
Some designs use PWM to control the intensity of light and/or manage heat generated by the LED and its driver circuits. This can exacerbate the total EMI generated by having both conducted and radiated EMI.
This is also true of poor designs for flourescent light fixtures and vapor lights than operate at high voltages and high frequency.
Note that a car accessories runs in DC current, and backup lights are low power. These backup LED lights have multiple LED that are connected in series and powered at a fixed current. So no alternating currents to produce EMI.
In a world filled with Wi-Fi, cell phones, Bluetooth devices, electronics, radio, TV, certain materials, sun, and stars, etc. we are constantly bathed in electromagnetic radiation, Some radiation can easily kill or cause damage (UV, X-Rays, Gamma-rays, etc.). There are numerous studies to determine what is safe, but it basically depends on short term and long term exposure, frequency of radiation, amplitude of signal, distance from source, and cell biology. Some of the studies are inconclusive For instance, does talking for hours with a cell phone next to your brain, kids playing under high power lines in a school for several years, or having numerous long high-altitude flights high have the potential to cause cancer or not? So minimizing exposure is good, but it most of it is hard to avoid. Nevertheless, we know how to design circuits to minimize EMI, it can be tested, and there are standards to meet, so except for greed, there is no excuse to not minimize EMI by manufacturers.
bamalam (01-21-23)
