How do you mount front license plate?
#31
I attached mine the same way hon3kong did. The OEM bracket has two hooks on top and when aligned against the grill the hooks will grab one of the slats and stay in place. It's pretty secure for me so far.
The two screws that came with my OEM bracket would have been too short if those are the same screws to be used to secure the bracket against the grill. I use those to secure the plate against the bracket.
My Lexus dealership still insists that I need to drill two holes and I told them I'll take my chances
#32
My Lexus dealership still insists that I need to drill two holes and I told them I'll take my chances![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#33
Can someone tell me how the front license plate attaches to the RX? My IS 350 simply screwed a bracket into the plastic bumper and then the plate attached to the bracket...I hope things are better now for those of us who don't choose to run front plate (even if our state 'requires' it).
#35
My 2016 RX 350 front bracket just snaps on the top of the first grill slat above where the solid slats stop. Seems very firm and solid. I am not mounting a plate atm, so took it off. The screws provided are short and don't seem to turn into the threads easily to mount plate to bracket without cross threading. But, didn't try to actually screw them in. The bracket is about one-quarter to half inch wider on either end then my plate. And plate is taller than bracket. So, part of plate extends below bracket. Not looking like a safe method for going thru car washes. But, bracket color seems to match grill color.
I will wait for my first warning or ticket before pursuing this.
EDIT: Saw where the two dimples are on the bracket and slat for drilling and using the provided screws to attach to the top flat, horizontal slat. I would need to drill holes in plate to better attach the lower part of plate to bracket to keep from being bent by long, vertical cloths in carwash.carwash.
#36
#37
+1. To put it another way, look into the grill and look for the bottom-most slat where air can get into the engine, that is where the protruding hooks on the plate frame snap in. Just put those hooks through that slat and snap the frame in, then if you need to, you can slide it left or right to center it.
#38
I have a 2016 RX350 F-Sport, and the front license plate mount that came with the car is wider and shorter than our CA License Plates (and hence and license plate frames). How has anyone else dealt with this issue? And since I'm in CA, the front license plate is required :-(
Thanks Guys!
Joe
Thanks Guys!
Joe
#39
Thanks Guys!
Joe
Thanks Guys!
Joe
#40
#41
I see what you mean-I can tell you that the one I got is just right with relation to the plate, so my guess is they may have accidentally given you one that was meant for a foreign plate? See if your dealer can scare up a normal one for you.
#42
Just kind of weird that a dealership in the US would have a mount that doesn't fit US plates.
#43
Can anyone please confirm if the F-Sport has a front tow hook connection? Was planning on using a tow hook licence plate holder, but can't seem to find it on the car or in the manual.
#45
I have the plastic Lexus supplied front license plate holder. Ibelieve I have it in the right place but how do I install the two screws that fasten it to the car?
