Koonlung K1S camera question
Hello,
I have the K1S camera system and have 95% installed it... the cameras are installed, the wires are run, I have found the fusebox under the dash (quite a pain honestly). Currently I am using the cig lighter for my power supply as I am unsure which fuse to hardwire/piggyback to? and what size fuse to install for the camera system? Problem with using the cig lighter, we have a hybrid and when you come to a stop light it automatically shuts the system down. Any help on this will be appreciated.
Thank You!
450h4bvrs
Thank You!
450h4bvrs
Thank you for the reply, amazingly it does not, since it plugs into the cig lighter I doubt it is much also but, I can be OCD about things like this and I dont want to mess anything up?
Amperage ar 12volts can be quite dangerous. I had a friend who's car burnt to the ground because a short while charging a phone while she was shopping.
Depending on your wire gauge I would keep it at 1amp or less. Have not looked at the fuse box but a spare should be available. You can buy connectors that fit the terminal in the fuse box.
Agent$mith
07-13-16 07:35 PM
