Bad tire replaced with a different brand.
Consider going to www.tirerack.com and bring up both your tire models. The Michelins may show better
results, it is up to you to compare your driving needs and budget. The fitment pitfalls mentioned by dibl
should not deter you from getting the best tires for your specific conditions.
The OEM Michelins are not great either. Ours were toast around 40K miles. We replaced with Goodyear Maxlife Assurance. They are quiet, smooth and tread definitely will last longer.
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/1065x758/5c33e5e8_d848_4112_a8ec_bc6cb6844067_9b6d1de6396c35da6e4b22bce74383c31f59ea89.jpeg)
If your RX is AWD drive replace all 4 like dibl suggested. If FWD you have the option to replace (2) with the same brand & model you have depending on the wear buy 4. Note: it's easy for me to spend your money
As for which tire to buy we all have our opinions on what we like such as ride & handling also depends on what region you live in for weather conditions. In my experience I like the Continentals better than the Michelins, but would choose the Michelins over the Bridgestones on a RX. I also suggest going to Discount Tire they give you 30 days to return them if you don't like them for something else. I've done this many times with my cars, and purchase the optional warranty. They will replace your tire if it can't be repaired it pays for itself if you use it once. I've used it twice on my daughter's car for unrepairable tires.
Let us know what you decide on....
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
I suggest when you're ready go to Discount Tire they will tell you the manufacture size, and model for your RX. Again tires are like shoes people like what they like, but stick to the main brands should be rebates on them too.
To answer your question I looked up FWD RX and the Continental CrossContact all season tire rated for 70k miles. You probably will be ready to change them out around 60k miles imo.
I just replaced my Michelins that I only got 30,000 miles with the Pirelli's. I bought them based on rated #1 out of 38 tires for my size. The Bridgestone's are rated #36 out of 38.
I've heard the OEM Michelins folks are getting 30-40k out of them. So far I haven't kept an RX over 30k miles.
dibl (04-08-21)
Related question. I have a 2017 RX FSport. Bought as CPO last September with 29K miles. Now have 35K and hit curb and blew out sidewall on front passenger side (no curb rash, thankfully). The tires are the Ecopias, and were new when I bought car (so 6K miles on them). Is it okay to just replace the one tire given the low miles on the tires or should I do them in pairs?
Note -- that car was totaled in a wreck at 33K miles, so we'll never know how accurate that advice was in the long run. You should discuss it with your dealer, since you're still under warranty. For sure, you don't want different diameter tires on the same axle.
coolbrazz (04-09-21)
Also if AWD make sure that the tread depth difference between all the tires is within specs.
Thanks dibl and Cocal. That was my thinking as well. I bought one tire with the idea that there are only 6k miles on them, but after comparing new to old, there is a significant amount if tread loss on the Bridgestones. As others have experienced, the Bridgestones wear down quickly. Will replace 2 for now, but no more of these Bridgestones after they're done.
dibl (04-10-21)
