Turn on/off Air Conditioner?
Old 04-17-21, 06:31 AM
  #91
golferjack
golferjack's Avatar
The compressor not only cools, but also controls humidity even on 20 year old cars. On the hybrids the compressor is driven by a little motor and so there is no drain on horse power or MPG.
When the air conditioner comes on and it is too cool, I just raise the temp to "turn off" the air flow from the vents or I just go directly to the dash button that manages where the air flow is directed and make the air flow go to my feet. The only problem with the later is that the system is not on Auto any longer.
Old 04-17-21, 07:05 AM
  #92
Cocal
Cocal's Avatar
Default Following-Up on my previous post
This is the "OFF "button I use to turn off the fan and it does it instantly, it does not, however, turn off the compressor, but the cooling stops immediately.
dibl (04-17-21)
Old 04-17-21, 07:10 AM
  #93
Bylan
Bylan's Avatar
A/C does not only cool air, its main function is to remove moisture from the air to make cooling or heating it much more efficient. The reason Lexus has taken away the A/C button is because the compressor should be running in most all situations. You need A/C to cool the interior, run the defrosters, and provide heat. Many people have this misconception that A/C makes air cold. No, it conditions the air.
Old 04-17-21, 08:34 AM
  #94
golferjack
golferjack's Avatar
How do you know it turns off the compressor? I thought it just redirected the air.
Old 04-17-21, 08:37 AM
  #95
Cocal
Cocal's Avatar
I said it does NOT turn the compressor off, but it does stop the fan thereby stopping the cooling
Old 04-17-21, 09:04 AM
  #96
artem123
artem123's Avatar
Forgive me but how redirecting airflow button stops the fan? I am puzzled))
Old 04-17-21, 10:55 AM
  #97
Cocal
Cocal's Avatar
Where does it say that by turning off the fan one redirects the airflow? The airflow stops completely until you reset it by pushing the auto button or the fan button you can then select how the flow will blow air.
Old 04-17-21, 01:29 PM
  #98
artem123
artem123's Avatar
lol)
your red trim removal spatula pointing on airflow button. That confused me. I am easily confused nowadays)
Old 04-17-21, 03:06 PM
  #99
Cocal
Cocal's Avatar
lol)
You and me both, there are times when I think that I'm playing Who's on First all by myself! :-)
artem123 (04-17-21)
Old 04-18-21, 07:04 PM
  #100
Tarkus
Tarkus's Avatar
I'm sorry Bylan but there is no "misconception that A/C makes the air cold". It lowers the airs temperature. Period. The evaporator is usually 40 degrees F. As a result when warmer air passes over the evaporator the water vapor in the air, humidity, condenses on the evaporator coils thus lowering the relative humidity in the cabin which makes it easier for your sweat to evaporate making you feel more comfortable. So to keep the cabin at 72 degrees you have to heat the air coming off the evaporator.
Old 04-19-21, 02:32 AM
  #101
dannnn
dannnn's Avatar
A/c's can also heat... An ac condenser is a form of heat exchange and the direction in temp doesnt matter, an ac can be used to heat or cool. The only difference of a heat pump and traditional ac is that a heat pump has a reverse flow valve which allows it to heat and also cool air temps while providing the benefits of acting as a dehumidifier.
Old 04-19-21, 10:36 AM
  #102
Tarkus
Tarkus's Avatar
Is this a Lexus feature?
Old 04-27-21, 10:31 AM
  #103
kentuckyed
kentuckyed's Avatar
I have to also chime in here. Our 6 month owned CPO 2018 RX350 must go through the mouse interface to turn ON the A/C in a manner that makes sense to me. Other button push sequences may also turn it ON but it's not an intuitive process, for me at least. I realize that pushing a defroster button will likely turn the A/C ON to get the demister function, but that's definitely not intuitive for my wife. I'm just now teaching my wife how to use the mouse to turn the A/C ON. Remember, first hot season with this car so it's all new to her. The lack of a hard A/C ON button is just in keeping with the non-intuitive man-machine interface on this car.
GeoMan
GX - 1st Gen (2003-2009)
09-24-17 12:11 PM
StinkyBoy
04-18-14 10:07 AM
LexusVet
GX - 2nd Gen (2010-2023)
02-06-13 12:35 PM
Gs350Lola
01-24-12 06:10 PM
RXGOLD
02-14-05 03:23 PM
Quick Reply: Turn on/off Air Conditioner?
