Low brake power light, RX not starting?
#226
#227
Any More Problems
Very happy camper! Had these same issues, car made horrible sound, low brake power, all sorts of random error codes showed up and wouldn’t start. Was so hoping it wasn’t the vacuum issue. Jumped the car and boom...started like a champ. Went to autozone got a new $200 battery (why the hell are they so expensive) and the car is like new. So happy I didn’t pay to tow to dealer. Car had original battery and I guess 4 year battery life isn’t so bad in Houston.
#229
Same issue, new battery solved it!
I had a similar issue on my 2016 RX350. My situation was the car was dead, kept clicking/turning over when trying to start it. I tired recharging my battery and was met with a bunch of errors (see photos - first displayed Low Brake Power for a second and then showed the AWD malfunction error). After reading multiple forums regarding the Low Brake Power and AWD messages, I ended up buying a new Interstate battery, let the car sit for 30 minutes to reset the ECU before connecting it, hooked it up and everything cleared and is working great!
#231
Low Brake Power - misleading
Error Messages: Low Brake Power
Read many comments on this board. Some say Brake Booster and some say Battery. Called CAA. They came and jump-start the car. I let the car run for a while. Shut it off. The car started again and again. Told my wife not to drive unless getting stuck. I'm looking for a new battery. I like Interstate batteries.
Interstate BESTMTP-24F Group Size 24F 750 Cold Cranking Amps (CCA) 30 Month Warranty 750 Cold Cranking Amps (CCA)
CAN $284.95 MSRP
Or
Super Premium - MTZ-34R Group Size 34R 800 Cold Cranking Amps. (CCA) Group Size 34R Mounting Flexibility Almost 3X the life of conventional flooded batteries
Absorbed Glass-Mat (AGM) 40% more cranking power. Plenty of power for accessories and plug-ins - even while the engine is off
CAN $544.95
CAN $284.95 MSRP
Or
CAN $544.95
LexusFan2
ES - 5th Gen (2007-2012)
13
10-06-22 05:27 PM
CaptDank
01-10-22 09:29 PM
