Oil changes maintenance Schedule
#226
Thanks everyone. Went back out now and found it in an ajacent part of the Settings display. I needed to carrot left in the display to bring a different part of the menu up showing the oil / maintenance reset. One keystroke that was not listed but know how to get to it now that I found it. Again Thanks
#227
First oil change at 1000mi
I've always done a break-in oil change with my new cars. Since the filter on the 2GR is pretty easy to take apart, I decided to take a look. Pretty surprised to see how much I found. With that said, I know the filter was doing it's job and the oil coming out on the other side is likely clean. But I'm hoping to keep this car for a very long time so there was no way I was going to wait until 10k for a first oil change.
All pleats had same amount of material.
The following 2 users liked this post by JohnnySack:
FMY421 (04-12-23),
RaiderHawk (10-31-22)
#228
I'm with you on that. I did my first change around 1K miles. My car is closing in on the 50K mile service. I bought a Blackstone oil test kit for the 45K mile change, which I did myself, and it's all good in all parameters.
As far as the filter, not sure what those little bits of stuff are, or whether they came out of the engine oil or were already there. Nevertheless, not a bad idea to replace that too at 1K miles. Wix makes a nice filter kit for the 2GR.
#229
Same here with oil change when breaking in the engine. I waited a little longer and changed the oil and filter at 4K, then got the free oil change at 10K. I didn’t check the dip stick when they changed it. In my last oil change I noticed oil seeping down from the timing cover area. Gonna take it in for possible warranty work.
#230
Conflicting Maintenance Info
I recently bought a used 2022 Lexus RX 350 from a Chrysler dealer. The car had approx 24,500 miles on May 21, when I bought it. Now I'm getting some conflicting info, as follows. (I've rounded all the numbers.)
Thanks.
- There is a dealer sticker on the window that says 28,000 miles. I have about 25,000 miles on it now, so I should have about 3,000 miles to go before I need an oil change.
- I'm getting a pop-up error message NOW, at about 25,000 miles, that says I am due for Maintenance.
- When I check the options for Odometer, Trip A, Trip B, and Maintenance, it says that I am due for maintenance in another 8,500 miles, which would bring me to about 33,500 miles.
Thanks.
#231
Thanks.
Thanks.
#232
Thanks.
Thanks.
#233
Thanks.
Thanks.
Congrats on the new ride!
#234
Thanks.
Thanks.
Pull the oil dipstick out while the engine is cold and look at it closely. Since you have put only 500 miles on the car, the oil on the stick should look fairly clean, if the dealer changed the oil. If it looks cloudy, dirty or dark brown then there is no telling. In that case I would change it right away and not take any chances.
ravenuer (06-19-23)
#235
10k Mile Oil Change Interval?
Hi Guys - have a question about the oil change interval. I have an 18 F Sport, L certified, and 4 services were included. Last time I was at the dealer, the advisor indicated this service didn’t include the oil change as the RX oil change interval was every 10K. Is that accurate? Also, do you guys go 10K when changing the oil or do you do it more frequently. My wife pretty much drives the RX, all local driving, so she only puts like 3-5k/year, so at a minimum I’d change the oil at least once a year. Presuming the “normal” mileage a year, do you guys wait 10k or do you change the oil more frequently?
Thanks to all who answer!
#236
Every 10K miles is the official Lexus recommendation.
Only a fool would follow that. Change it every 5K miles. On youtube.com, search for the Car Care Nut channel. There's a great explanation there.
The following 2 users liked this post by dibl:
jcg0324 (09-05-23),
Quantum501 (09-06-23)
#237
I'm going to follow what my car manufacturer and oil manufacturer (Mobil) recommends which is 10,000 mi oil changes. They have incentive money-wise to have me change my oil more frequently. If you go out on the web and search synthetic oil interval mileage changes 10,000 miles is the standard.
ravenuer (09-06-23)
#238
Ohh, remember, never change your transmission fluid unless you tow, and take your car to the dealership every 5k miles because Toyota said so, and it's not out of their self interest.
#239
An Exception to the 10K Mile/12 Month Oil Change Requirement?
I completely understand that fresh motor oil and oil changes are cheap insurance and are absolutely crucial to the life of an engine. I also know that multiple short trips are very bad for an engine since some of the moisture generated by combustion condenses in the oil, and if the engine has not warmed up fully to boil off this water, then the result will be increased engine corrosion. For this reason, Lexus says to change your oil every 10K miles or 12 months, whichever comes first. Makes perfect sense for those cars driven the usual 10-15K miles per year.
One of my cars was bought new in 2020 and because of COVID-19, and because we tend to use our other car much more frequently, this car has only been driven about 5,000 miles (it’s on a Battery Tender until we need it). But, importantly, I know that when we do take it out, that we drive 20 or more miles until the oil is completely warmed up. I’ve long known from my Vette which had an oil temperature gauge, that the oil takes far more time to get to temperature than the coolant.
So, my argument is that, ignoring warranty concerns, that waiting a bit longer than 12 months does not do the engine any harm under these driving conditions. I am certainly not suggesting delaying the oil change until 10K, but it seems to me that changing say every 24 months or so under these circumstances would not harm the engine.
Interested in everyone’s thought on the subject.
#240
But since you don't drive that much it isn't going to matter either way.
At 5k miles a year, the rest of the car will require maintenance and repair before you get engine oil related issues anyway.
Say your usage and maintenance pattern causes the engine to only goes to 200k miles, that sounds bad for a toyota, but due to such low usage, that's 40years and past it's practical lifespan. Gasoline will be $40 a gallon and majority of people will be in evs operating at a fraction of that price then.
Should the car return to more active usage return back to the normal service schedule.
