Oil changes maintenance Schedule
#46
Yep - Main Menu, Setup, Vehicle, Maintenance and there's stacks of things you can change, oil, oil filter, coolant, air filter, even personal reminders (3 of them) like birthdays, anniversarys , whatever you type in. And you can put in a date and mileage for when the reminder is to come up.
#47
Most likely an algorithm that stores all the engine parameters and other environmental factors like temp, humidity and such. For example, short trips in the winter without the engine getting completely warmed up would most likely trigger this alert over time.When certain criteria are met, on comes the light.
#48
I’ve searched the owner’s manual and the warranty and service guide. I can’t find anything that shows where you can change the date or mileage of the oil maintenance reminder.
I found 3 videos that show how to reset the oil maintenance reminder. All 3 show reset data only (no additional choices) .
This is 1 of the videos.
#49
Can you help me find instructions to the procedure you are referring to?
https://www.youtube.com/watch?v=DBXY6muk1VA
#50
Unlike the German cars which tend to be over-engineered at times, I'm not convinced our RXs have such sophisticated oil management monitors in them.
My guess is that the maintenance minder is just a value entered by the dealer based on how often they think you should come in for an oil change. For example, here in Canada, while it says 1 yr or 16,000km (roughly 10k miles) in the manual as well, I believe there is a section in there for "Severe" Maintenance schedules, which all dealers love to set for our Canadian cars. That means every 6 months/8,000 km (5,000 miles), the oil change reminder will pop up.
The reminder intervals can be manually changed in the Maintenance settings on the Nav screen.
Also when the message comes up there is an option on the screen to delete it or some equivalent.
#51
#52
Thanks again... I did in fact find it in the Nave screen. There are many maintenance options and schedules in that area.. Very cool.
#54
Getting back to oil changes ... 0W-20 oil only comes in full synthetic; thus, all 4th Gen RX350's take full synthetic oil and have a 10K oil change recommendation - unless your driving falls under Special Operating Conditions (aka severe service, i.e. towing, off-roading, long idling, etc...), in which case, Toyota recommends 5K oil changes.
https://drivers.lexus.com/t3Portal/d...MS-18RX350.pdf See pg 44.
#55
#56
Me: 07 Tacoma 4X4 DCLB; 161K
Mrs: 18 Lexus RX350; 040
Mrs: 07 Lexus ES350; 218K
Dau1: 06 Toyota Camry I4; 165K
Dau2: 07 Toyota Corolla; 134K
Mom: 98 Toyota Sienna; 247K
jettzen (11-14-22)
#57
Ha Ha. Just sold the ES350 to daughter's BF, but will continue to maintain it for him as he don't know cars much and many of the 'lifetime' parts I have bought for it are under my name. Gonna update my sig soon ...
#60
I'm doing roughly 7K. If you own and you plan to run it beyond 100K miles, probably pays to be more proactive. If you lease, who cares then.
