Lane change blink setting...how to change?
#32
Hi. Thanks for the tip.
Just got back from the dealer for a body side molding install and on the side, dealer changed the auto turn signals from 3 to 5 blinks for free.
regards
regards
#34
I would think that it could be done on any RX.
Programmable by dealer only.
35. Lane Change Signal Flashes
Push the turn signal lever partway to signal a lane change. It will flash:
□ Off
□ 3 times (Standard) □ 4 times
□ 5 times
□ 6 times
□ 7 times
□ Off
□ 5 times
□ 6 times
□ 7 times
#36
This above will not work on a current RX. Either a dealer of Carista with doggle needed to change
#37
Lexus Personalized Settings
Your vehicle includes a variety of electronic features that can be programmed to your preferences. Programming of these features is performed once at no charge by your Lexus Dealer provided you obtain the service at the 6-month/5,000-mile scheduled maintenance service.
#40
thanks for the info. question, if the Carista is plugged in and accessed through an IOS app on your iphone... what the the purpose of the OBII cable? does the Carista not plug into the car's OBII port?
I believe you also need an OBD2 adapter. The official Carista one is supposedly quite good: https://www.amazon.com/Carista-Bluet...ywords=carista
Most of the negative reviews are from people who either didn't know their vehicle wasn't supported, or didn't realize you had to also buy the $20 pro app in addition to the hardware. So $40 for the adapter and $20 for the app will allow you to change anything you want that the dealer would want to charge you for himself.
#45
Our 15 RX 450h could be done in the menu setting by us. Our 17 can only be done at the dealer. Defaults to three blinks which is way to short. Had ours changed to five.
