Is it possible to reset the default screen not to be map every time?
Old 06-26-16, 12:53 PM
pdaeng
pdaeng's Avatar
Default Is it possible to reset the default screen not to be map every time?
Went through almost all the menus. Still can not find where to set (or impossible?)
Thanks
Old 06-26-16, 01:43 PM
aznkorboi
aznkorboi's Avatar
Yeah! Im not sure where but it IS in the menu somewhere....
I have mine on media on the left and the ac controls on the right and it always defaults to that.
I think the setting is default to the last screen used or something on/off. Gonna check tonight when it cools down.
Old 06-26-16, 10:11 PM
dchar
dchar's Avatar
Setup. General. Auto Screen Change. Off
Old 06-27-16, 03:06 PM
pdaeng
pdaeng's Avatar
The Auto Screen Change is off. But still come back to map every time.
Old 06-28-16, 11:25 AM
sc400
sc400's Avatar
Don't know about the '16 model but in my '13 I click Media button which changes the map to music screen. That's all. Every time I drive it always default to the music screen.
Exception is when I make/take a phone call it always default back to map after that. This is a bug but another click on the Media button takes it back to the music screen.
Old 06-28-16, 06:02 PM
frubalup
frubalup's Avatar
Mine defaults to whatever was being used last, I don't believe there was any setting I changed other than turning off auto screen change.
Old 05-08-18, 10:32 AM
Kewhouse
Kewhouse's Avatar
Default 12.3 " Display screen RX
why does my screen always revert to map??? if i bring up the radio (stations) after around 30 seconds it revert s to the map which means you never see the title of the song being played
Old 05-08-18, 01:29 PM
Dewillia
Dewillia's Avatar
You can change it in settings, can't remember the item but it is there
Old 05-08-18, 07:21 PM
Jiggz858
Jiggz858's Avatar
You can change the Home Screen as follows: Menu->Setup->Customize Home Screen. Choices are: Nav, Audio, Fuel Consumption, Climate, . . .
Old 07-26-19, 07:37 AM
IrvSp
IrvSp's Avatar
Question 12.3 Navigation question.
New RX 350 owner. Perplexed by screen operation? I can set it (main screen, side screen too) be what I want on the main screen with no problem. However within a few minutes the main screen changed to the MAP display? Is this 'normal'? Is there a setting to alter this happening? Is it possible to set it to always have what I selected showing or is this a case of the map alerting me to something (I can see that is has?)?
Old 07-26-19, 12:08 PM
winstonchu
winstonchu's Avatar
I ran into this as well. Go into Menu --> General Settings --> Auto Screen Change and then set it to off and it should fix it
IrvSp (07-26-19)
Old 07-26-19, 12:24 PM
IrvSp
IrvSp's Avatar
Thanks, did it, looks like that is it.
Old 07-29-19, 02:26 PM
ISFWes
ISFWes's Avatar
I just picked up a CPO RX350 a couple of weeks ago. With the 12.3 Nav screen This past weekend I went on my first long distance trip.
I played with the system during the whole trip. And every once and awhile it would lock up.
Example the scale up and down switch wouldn't work. Like on the Navigation Map or Radio selector.
About day 3 into the trip I realized you need to have the cursor on the side you were working on. So when you run a split screen. Say Map on the left and music on the right. Put the cursor on the side you want to change.
Old 07-30-19, 04:24 AM
PeeVee
PeeVee's Avatar
While reading I was going to tell you just that, but in the end I saw that you figured it out!
eeMatt
05-28-21 06:52 AM
Riva
RC F (2015-present)
06-30-19 09:48 PM
IOWNALEXUS
03-20-15 07:42 PM
dseag2
08-20-12 07:42 AM
The Godfather
10-26-10 03:31 AM
Quick Reply: Is it possible to reset the default screen not to be map every time?
