Remote start not working
I have a 2016 rx350 and for some reason the remote start is not working. I tried it with the enform app and got an error of failed for request when I tried to start the engine. I had no issue with unlock/lock the door with the enform app.
Have you set up the Enform app?
Mine does this from time to time. I noticed it's usually in areas where there's bad cell signal.
No, I don't play soccer!
I meant to add, make sure the doors are locked. And maybe try remote start using the fob. Hit lock three times quickly, then hold the lock button for a few seconds. The hazard lights should flash about three times before the RX turns on. That can help rule out a mechanical issue,
