Garage door programming
#32
Step 2, let the home link learn your remote. Again when it learns the remote signal the light blinks at fast rate confirming it. Step 3 Let your GDO learn the home
link signal. Push learn button on the GDO, within 20 second keep pushing the button on the home link repeatedly until garage door moves. Important thing here is to distinguish home link light blinking rate. Blinking slow means whatever you were doing it is not accomplished. When blinking fast, the task is accomplished. As already mentioned if the GDO is fairly new, you may have to get a bridge module which will be installed inside garage. Also if you don't have a remote fob, home link ain't do anything for you.
elimmigran (09-09-17)
#33
What is your GDO, vehicle model? step 1 is as already mentioned, clear the Home link memory by pressing button 1 and 3 together until light blinks at fast rate
#34
Should I be able to program the garage door buttons in the Lexus to different garage doors in 2 different locations (my home and my mother's home)? For example, button 1 for my home and button 2 for my Mom's.I haven't had the opportunity to try my Mom's home yet. Thank you.
#37
#39
We just took possession of a 2018 RX 350 and I am working my way through learning the bells and whistles. Had some trouble with programming our garage door opener and had to get the salesman to help us since it appears the owners manual instructions are misleading. I was told that the RX could not be programmed to open a gate (ie in a gated subdivision). I find this hard to believe. Has anyone done this and what were your steps to the programming?
Thanks in advance for the advice.
Charlie
Charlie
#42
It all depends on the technology of the gate's open/close system. If the entry point to your subdivision has support for HomeLink standard, then you should be able to program the RX using the physical fob. Same way you program a garage door opener should work for the gate as well.
EDIT: While I have never done this, I have programmed a gate opining to a warehouse in Calgary to one of the buttons on my 2017 RX mirror. So I don't see a difference.
#43
Your garage door opener is likely a "rolling code" and that's why it was a bit more difficult to enter into the HomeLink on your rearview mirror. Your gate remote is likely much simpler and all you need do is press, but don't hold, the HomeLink button you wish to use (if it has not already been programmed) and it will flash orange. Then simply hold your gate remote close to it and hold the remote button down until the HomeLink button light stops flashing orange and turns green. That's how I entered my gate remote. Some handheld remotes are momentary (you hit the button and it only send a brief signal for a limited amount of time); you'll need to use a remote that continuously sends a signal when you press and hold the button. I hope this helps.
#44
I just bought 2018 Lexus RX 350. I need to program my garage door to open however the remote opener is lost. Is is possible to still program the car remote opener with the actual remote that came with garage opener system?
