Winter Tires and Rims
#166
Wow you seem to be quite well equipped!! You must cover about 20,000Km yearly, I'm far from that. On my MB E350 I used Continental all weathers though they weren't so classified, I think for liability purposes and changed them after 5 yrs with the same tires and brand, they performed well, but my weather here in the GTA is far different from yours, I think that if were in your neck of the woods I'd be taking a really hard look at the Hakkapellitta r2, though very expensive it's like having tracks instead of wheels ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
We just drive like 25 Km a day going to Seniors club. When we go out to cabin in the woods, that is 250km round trip on highway mostly.
Today temp. climbed back above freezing. We may have flooding from melting snow, LOL
#167
I got transferred out here in 1970. I used to live in Scarboro near the Sinclair subway station. Retired in 2002, GTA must be changed a lot since.
#168
Hi there,
I have a set of Lexus 19" Wheel from my old 2015 RX350, P235/55R19. I'd like to use them as my winter set for my new 2018 RX350L. I wonder if they will fit.
Thanks,
AT
Thanks,
AT
#169
The rims should be a perfect fit, since the bolt pattern etc should be the same. The tires though, are a bit too low. 3% lower overall diameter; according to the wheel size calculator site. For 19" rims, if you want to stick with the 235 width, you'll need to replace the tires with 235/60R19 to get them within 0.2% of the stock 235/55R20.
#170
Just a noob question, what happen if I just re&re with P235/55R19? You said it would be a bit too low. Would it affect the car safety or performance?
Thanks again,
AT
#171
BUT the 3%, I wonder if it is in diameter or in circumference... I don't recall.
For my winter tires, I bought the OEM Lexus 18" mags (not the same ones than delivered with the base package, they are nicer) with 235/65R18. 1200$ for the set of four.
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1124/20171013_102407_a5080f959f5591b0005b333cd1466e975a4d2d56.jpg)
#172
After searching on internet, I can not find any 235/60R with 19', Would you have any site with the tire size conversion?
Thanks very much,
AT
#173
Tirerack also gives you options if you specify your car and a custom wheel size. Just looking at tirerack, it looks like their default option for a 19" rim that fits our cars is 245/55R19; which according to the wheel size calculator is down -1.9% overall diameter.
A better fit might actually be 255/55R19, which Tirerack has plenty of choices of tires for. Diameter is within 0.4%. It is a wider tire, and I've heard some people say skinnier tires are better for snow/winter, but I'm not sure if it matters to you.
#174
I really like them and my next door neighbour after seeing mine also bought them, but they are not the same type of tire, the Michelins were summer ones and these Toyos are all weather (not all seasons) so that I don't have to change tires every 6 months. Michelin had all weather but not in 20" alas.
#175
Yes I know, I think it will come soon to Ontario as well. Way overdue, when I see the morons trying to negotiate a slight hill with ice being a danger to themselves and others I say it'll never be too soon.
#176
But the threading is different too. It has small close lines (verry noticeable on Michelin X-Ice tires) to keep a good grip on ice, and the larger ones are designed to grip on a snowy surface, as well to be able to evacuate properly water and slush.
The ideal temperature range is bellow 10 degrees Celcius to avoid too much wear.
One would choose his winter tires for the most encountered conditions of the roads used. Someone that roll mostly on highways and city would choose a tire more designed for gripping on ice (like Michelin X-Ice). For me I live in the suburb and roll more in snowy conditions, so for me the best choice is Bridgestone Blizzak DM-V2.
Here is the thread of the Bridgestone:
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/1377x622/dm_v2_70344f59232d70803294ec52ed0d9da555e14c1c.jpg)
And here is the thread of a Michelin X-Ice
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/420x335/19_hero_latitude_x_ice_xi2_1_tread140513_9811fc753d4f6927dd6aefdd81ef3b75dd1b493f.png)
#178
PeeVee, so then it's strictly winter tires only. If you buy a new car during the winter, what would the car come with? What does the dealer do with the OEMs?
Sorry, I'm just curious.
#179
I bought in spring (20 " wheels) and at fall, I bought by myself a set of 18" mags and TPMS (Lexus) and winter tires (Costco) for my winter set. I change my wheels by myself at fall and in the spring.
Most people buy a separate set of wheels and tires, but some just make the change of tires on the OEM wheels, but have to go to a garage to do it.
ravenuer (12-13-18)
#180
All Seasons are out! You can use an All Weather IF it has the 3 mountain peaks & snowflake printed on the outside of the tire (Most do), it means that it has been winter approved. All winter tires in Canada have the 3 peaks & snowflake showing that it has met all the requirements for winter driving
ravenuer (12-13-18)
