Winter Tires and Rims
#211
Blizzaks are great winter tires - I had them on a FWD sedan I had a few years ago.
PeeVee (11-04-19)
#212
Encouraged to see some discussion about the quality of the Nokian Hakkas. I have always gone Blizzaks or X-Ice. After some research, it certainly seems that the Nokians have a bit of an edge for winter performance. Very happy not to be buying something made in China. Also looking at a set of wheels from Fast wheels. Whole package with sensors is around $2000 which is way more than I have ever wanted to spend in the past. But based on performance and look, I think I am making the right choice.
Cocal (11-07-19)
#215
I wanted to get their WRG4 for my vehicle but they did not come in 20" so I got Toyo, But I wish I could have got the Nokia. Now if you can use studded tires their nbr 9 is what I'd use.
OntarioTim (11-07-19)
#216
I don't know how I have never noticed these tires! I always google "best winter tire in Canada" and not until this year did it show up. But so many people like yourself endorse them. I will find out this winter what I have been missing out on!
Cocal (11-07-19)
#217
That said, you can get the WRG4 on our cars if you opt to go wider. Kal Tire (the only authorized dealer for Nokians in Canada) have the 265/50R20 listed. I'm tempted to go with those ones when it comes time to replace my OEM Bridgestones; but I don't like the fact that I can only get them from Kal Tire here...
#218
Have always had a soft spot for the Nokians since having them on my Acura and BMW.
#219
The only drawback is that KalTire is the only distributor.
#220
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
Good for you that you were able to get them, no regrets I can tell you.
#221
My oem wheels are the 20” fsport wheels..
i picked up a set of 19” fsport wheels from a 2015 - I am debating what size tires would be best.
i found a few available sizes
235/65/19 - about .8” taller - I think it should clear the suspension - any one have personal experience
235/55/19 - this is 1” shorter - would this look weird??? I don’t want that “huge wheel gap” look
245/55/19 - the wheel is 7.5” wide - would the 245 be too much “tire” for the width of the wheel?
^ any thoughts would be appreciated.
#222
https://www.wheel-size.com/calc/?wheel1=235-55-20X8ET30&wheel2=245-55-19X8ET30&fcl=50mm&scl=50mm&wcl=30mm&sr=0mm
In the MINUS section, for 235mm and 19", recommended ration is 60 which give an error of -0.2% compared to the 20" OEM wheels.
If you go with 55, the error is -3.5% (which is over the recommended max of 3%).
For the 245mm, it seems to recommend only in the PLUS section with diameters from 20" and over.
For the tire size availability, that is another story.
I would go for 235/60 R19.
#223
I had Blizzak 245/60R18 on my first 2016 RX 350, worked well. I would suggest you try to stay as close to the original diameter as possible.
#224
I haven’t seen any - the sizes I listed in post were the sizes I found snow tires available for.
to the other person that responded - I already have the 19” wheels - getting 18” wheels at the moment isn’t an option.
#225
I used my winter tires and wheels that were previously used on a 2014 Ford Explorer. Same bolt pattern, just needed different lugnuts and centering rings.
That RX was totaled in an accident (not my fault) with the winter wheels on it.
