Winter Tires and Rims
#226
What I meant is that a 245 width tire will work just fine. I would recommend you get the 245/55/19 tires.
I used my winter tires and wheels that were previously used on a 2014 Ford Explorer. Same bolt pattern, just needed different lugnuts and centering rings.
That RX was totaled in an accident (not my fault) with the winter wheels on it.
i was worried that the 245 tire would be too wide for a 7.5” whee.
what was the width of the Ford Explorer wheels you had?
#227
Last week I did a quick search and found Continental. But now it does not seem come up on my Google search.
I searched on Bridgestone (Canadian) site and found DM-V2 (model I have) at size 235/65 R19, which has 2.9% difference with OEM. Better than nothing!
The R19 for SUV seem difficult to find. There is more availability for cars.
#228
i think i saw the same thing (the site was like 1010 tires or something like that)
i was worried the 65 profile might be too tall and interfere with the suspension.. but after taking a quick peak there seems to be enough clearance. i was just hoping someone had personal experience.
looks like 235/65/19 it is..
#229
Will 18x8 +45 rim have enough clearance?
I'm looking at some 18x8 +45 rims for winter, will this width and offset fit without hitting anything with 235/65/18 tire mounted?
Thanks
Thanks
Tuzla1 (07-26-20)
#231
Good day to all, I am hoping for a little help regarding TPMS sensors. I just purchased 2020 RX 350 f sport with 20 inch wheels . I have brand new 245 60 18 with a new Michelin winters on aftermarket 18” rims, I know tires should be good. Wondering is there a difference between 2016-2020 tpms sensor
thahks
thahks
#232
thahks
thahks
Should be the same
#234
Winter Tires.
Hi. I am looking to buy winter tires and rims for my 2017 FSport 3. I have read a few recommendations about downsizing the tires for winter driving. I’m just curious if anyone here has stuck with the 20” size and if there was any issues in doing so? Or if you did downsize, what size did you go to? Thanks.
#235
17FSport3 (07-06-20)
#236
I live in a rural area of Ontario, Canada and we get plenty of lake effect snow and freezing weather. Lots of people run winter tires around here. If you are going to wear out tires over the life of the car, you may as well run winter tires. I have Blizzaks on 20" OEM rims from a previous RX that was totaled.
#238
I would prefer the 20” I’m just wondering why downsize? From your picture it seems that there is plenty of room.
#239
17FSport3 (07-07-20)
