Heated Seats and Steering Wheel not that Warm
#31
This has been an on-going issue with recent Lexus models. There are similar threads in the IS and NX forums. Most people will bring it to the dealer who will say things are "in-spec". It's just a design choice that Lexus made. Realistically, warmth is a subjective thing and for some, it just isn't going to be warm enough. It is annoying that the steering wheel is not heated around it's full circumference though.
#32
What's really stupid is that Lexus doesn't heat the whole wheel even if you don't have the wood trim. Same problem on the IS and NX, neither of which have wooden trims on the wheel.
#33
Ok, so after a cold spell here for the past month (and 2 months of ownership), I change my opinion and the steering wheel heat is actually much weaker than my IS and previous NX. I will definitely be making a trip to the dealer to check things out.
#35
Dealer will likely compare it to another RX, declare it to be operating normally, and then send you on your way. They really didn't care that it was warmer in other vehicles for me. Please let us know if you get a resolution from them that will help us. Good luck!
ggebhardt (01-16-17)
#36
My dealer tells me these seats are designed to reach max 25 deg C. 25 degrees is much lower than any other cars I've owned from WRX, ML350, E400, 320i, A6 from MY2002 to MY2014, and feels lukewarm at best.
#37
Just checked with Lexus. These seats have thermostats/sensors that controls the temp. On max setting they should be around 38 deg C give or take. This data can easily be read from OBD. When dealer says it is operating within spec ask them to show readouts from techstream. Also have them measure the surface temp with IR thermometer. I bet you the temp will be around 26 even on max setting which is lower than your body temp.
#38
#39
I have test driven a 2016 on 2 separate occasions now, and one of the items that is holding me back from trading my 2013 - which I love, is the performance of the heaters ...i mean warmers in the seats and steering wheel...In the 2013, both work very well but in the 2016, I could barely feel the difference between full on and off. So if the 2017 appears to suffer the same fate, I won't be getting one....I have some arthritis in my back and the heat makes all the difference to me...even my 2015 Sienna has wonderful heat in both the steering wheel and seats. I am extremely disappointed with Lexus. Guess it is time to start shopping for a different brand - sad because i have been with them since 2003. They have stopped listening. I wonder which bonehead made the decision to reduce the heating?
dentate
Oshawa, ON &
Port Charlotte, FL
dentate
Oshawa, ON &
Port Charlotte, FL
#40
Sounds like Lexus has changed and has capped the temps for some reason.
#41
dentate
Oshawa, ON &
Port Charlotte, FL
dentate
Oshawa, ON &
Port Charlotte, FL
I'd rather have weak seat warmers/hand warmers than an engine that requires way more expensive maintenance and is a headache!
I bet it's the japanese dainty hands they thought it was PLENTY warm lol. Which is weird since they should be drinking tons of tea.
#42
#44
#45
