Windshield Leak Dripping from Microphone port
Thought I was the only Lexus owner with this problem. From replacing front windshield to new panoramic roof & many visits to the dealership. Car is processing for buy back with Lexus Corp, due to water leak.
Tia515 (10-29-17)
Just got my car (2017 RX350) back from the dealer for this same issue, water leak from the microphone port. They put it into the car wash for inspection and stated it was due to "excess clearance between sliding roof glass and sunroof opening causing water to leak in. Removed and replaced sliding roof glass panel and for tighter fitting seal." Hopefully it won't leak again.
Wow, sorry to hear about this. I wonder how long the process for the buyback will take. Please keep us updated!
I saw this thread before. So I checked, my 2017 RX did not leak, at that time. Even I have not touched the sunroof for months, even it did not leak in some heavy downpours, it leaks today. The dealer said it was a sunroof problem.
Mine is a regular RX with 3k miles. On the paper, they put a RX 350 F as my loaner. I thought I got a F Sport. But the F actually means FWD I guess.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
I also had my sunroof replaced. Have had other dealers since tell me they think the problem is that there isn't enough clearance between where the drain is and how high the rim is around the drain, causing water to puddle over and come in.
I wonder if a commonality has been determined on these leaky roofs or windshields? Was it only on the 2016 4RX or also on the 2017 4RX? Is it only with those with regular sun roofs? Or also those with Panoramic roofs? What about VIN numbers, is it only on Japan assembled (JT series vin #) or Canada assembled (2T series vin #)? I might have to do a test on mine using a garden hose just to see if there is any leak from the mic. This is a serious concern.
I wonder if a commonality has been determined on these leaky roofs or windshields? Was it only on the 2016 4RX or also on the 2017 4RX? Is it only with those with regular sun roofs? Or also those with Panoramic roofs? What about VIN numbers, is it only on Japan assembled (JT series vin #) or Canada assembled (1T series vin #)? I might have to do a test on mine using a garden hose just to see if there is any leak from the mic. This is a serious concern.
I have a 2016, pano roof with 2T as the vin from canada and zero issues!
Try the garden hose method and squeze water in as much as possible and see if it does anything.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
That sucks. We don't get very much rain in SoCal and my rides are always garage so I'm concerned that this may be an issue for me in the future. I may just park her outside during the next episode of rain to see what happens.
How concerning an issue depends mainly on two things: Gravity of the issue and then the quantity or number of those affected. In this particular case, the former is the reason I personally believe it is a serious concern. Maybe not for few people especially those who don't mind driving in the rain with their roof off. But for me, water intrusion in a brand new $60K car is a very serious concern. And yes I will try the garden hose test just to make sure it doesn't leak in the rain. I wonder how much water has to leak before it starts showing on the overhead mic?
I wonder if hybrids are at greater risk!
