I got my RX in early Dec 2015, so I had almost a full winter of driving it last year, and the warning went off 4-6 times. This winter, it goes off most every day. Could be 40F sunny, and dry roads and it goes off.
It is that time of year when there are large fluctuations of temperature in and around 37 degrees. Every time the multi-function display reads 37 degrees there is this annoying ding. I am well aware of the potential for slippery road conditions. Is there any way to turn the ding off. I don't care if the display presents a message.
It's in the same category as seatbelt warnings and door ajar warnings -- you'll have to cut a wire to turn it off. Lexus is not going to get sued for failure to provide a freeze hazard warning.
Cutting this off would also remove outside temperature display.
When I have the climate control set on recirculate, it automatically turns it off when that silly "The roads may be icy" thing pops up. Can this be turned off? I don't need schooled on why this is necessary, I understand moisture and cold windows fogging up. But I still want to turn this off, if possible.
