HUD Display position
The HUD is not properly positioned, and cannot be shifted from right to left, or left tonight.
In a normal driving position, the speed indicator is cut off. To see the speed one has to sit to the left, very awkward. Lexus must correct this.
i have the RX 350 and mine is the same. I need to lean a little to the left to see my speed.
I have been unable to find a horizontal adjustment.
Is there a way to adjust horizontally?
MIne seems to have the right side slightly lower than the left side. Anyone else notice this? If you have the Tach displayed, it is a horizontal line, more or less, so being not straight becomes pretty obvious....
Been discussed here over and over. Worst, my LX is the same way!
If it's truly not centered, take it to the dealer. They will adjust it...They did on my 3rx.
I find sometimes I'm not centered in the seat. Sometimes my back is so sore that I lean a bit to the right, so I don't see the speedo that well. If I'm going 110 KPH I only see 11
Could be it's off a bit...only a fraction of an inch would be throw if off when displayed on the windshield.
Wow that seems really off-centered. Definitely let the dealer address the issue. They might be able to pop the cover off the surround for HUD and make some adjustments; worst case, they need to take the dash off.
Does not bother me enough to have them take the dash off. Most my driving is during the day and with my sunglasses so I do not see the HUD anyway. At the next service I will ask if they can move the image on the HUD to the left some but I am doubting that. Kinda weird that both are over center about the same amount and same direction. My 2016 RX was the same.
Same issue with my brand new 2018 NX300, were you able to get it fixed ?
slypx (03-29-18)
