Mark Levinson Rattle
Hi all!
I noticed the other day that there was a rattling sound in my 2016 RX 350 Luxury Package with Mark Levinson sound system. It seems like its behind the driver seat, I'm not sure if its coming from the back seat or trunk. It can rattle a bit with volume anywhere from 20 and higher, using iPhone with EQ Bass Booster on and usually playing songs with lots of bass (pop, hiphop, rap, etc). Any ideas of what this is?
Bass will cause things to rattle.
Best results are with less bass or less volume.
It it is all about physics.
You can take it to the dealer but they will likely tell you the same.
I would try to isolate it more closely, this isn't a high volume level.
I play my ML (I do have 2016 IS350) at 40+ power and no rattle whatsoever, including bass.
I have plenty of bass rattle in my old BMW's Harman Kardon but I blame it on a shot speaker.
I am super impressed by ML, never had anything remotely sounding so clean at such high volume.
Hi all!
I use my iPhone too. My bass is 2-3 below max.
I run around 20-25 with no rattle and I play edm etc.
take a video!!! Sometimes during manufacturing they may have forgotten too add a piece or left a screw. You never know. They forgot to put a screw in my door lol.
Hi all!
Hi all!
There is a big subwoofer under the trunk floor. If there is anything inside the under trunk storage or the trunk floor, it will vibrate and cause the rattle. Make sure the jack and tools are secured and tightly stored.
I didn't realize the sub was under the trunk floor as another user mentioned. I thought the sub was the speaker in the trunk to the left?
I always use a towel to line anything I keep in the side compartments on the doors and have had zero issues with rattling.
I agree, it's amazing how it's so clear as you scale up in volume. I don't have any rattle at all on mine even at max volume, I usually listen around 50 and it's so clear.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek.gif)
I should clarify that
lol When I am bumping out to music that is what I have it set to, above that is really loud.
I missed feeling the bass on my back (like when I was a kid and had a system in the car) and this is close enough for me, I love it!
Noticed the same on my 2016 RX350. The rattle wasn't there when it was new. It's now a year old. Sounds like it is coming from the drivers door. I will mention it on the next service.
Hello! The sub I believe is not under the trunk. It is directly to the left of the boot space. YOu will see a black meshed out speaker looking thing on the left rear of the trunk. There are woofers in all of the doors. Smaller but still produce mid bass. IF you have anything in the holders in the sides of the doors it will rattle.
I have the same problem and it's driving crazy.. seems to be coming from just over my left shoulder but I can't nail it down, I only get it with certain songs which I assume is due to different bass tones. Sometimes it sounds like it's from inside the drivers door and other times a little further back, I'm trying to isolate it but no luck, let me know how you do with fixing..
I have the same bass-rattle issue in the driver's door; seems to be around the the door lock post. Started happening a few months ago. Mine is the (non ML) standard stereo system. I don't play my music loud, nor have the bass cranked up. Very annoying...
