Brake pad replacement
#227
thanks for responding. The driver info said “Parking Brake Malfunction, see your dealer”
no idea what code, I don’t have a chassis function scanner or software for Lexus”
I went out on a limb and tried cycling the parking brake and the message is gone.
I was afraid they were going to lock up with it backed into my garage.
#229
Brake Pad/Rotor replacement suggestions?
I hate to go buy brake pads and rotors from Lexus because of their price. Anyone have a suggestion for parts for an 2017 RX350? Ive got 60,000 miles on the original pads and Im expected to replace them soon.
Volley (02-27-24)
#232
Akebono pads are well-regarded and are an OEM supplier for many brands, including Toyota (according to various internet sources. ADVICS is also a Toyota/Lexus supplier.) I just put them on a 2017 Honda Pilot. They were identical to the OEM pads I removed, minus 110K miles of wear.
seadonu (02-26-24)
#234
I have used Akebono pads previously on my Acura and they are great.
On my 2020 RX I just did my rear brakes (rotors and pads) and probably doing front very soon (same) and purchased OEM from online Lexus dealership. The cost is not bad for OEM and I figure it is once every 5 years or so for me, so not a big deal.
When I was driving about 30k per year I used Akebono pads and used Centric Rotors from Rock Auto. These were for my Acura TL (305,000 miles when I sold it) and they were a good and relatively inexpensive alternative.
seadonu (02-26-24)
#235
I used to be an Akebono fan until they had switched their brake material to copper free. I must say the brake pedal feels softer. And no, it's not because of there is air in the system.
As for rotors - aftermarket or OE have very similar thickness out of the box. So, it is for you to decide what is right for you.
#236
What's the thought on replacing pads without replacing rotors? My 2020 RX with 59K miles brakes fine with virtually no pulsation. My Lexus dealer, though, noted last week during a vehicle inspection (it's a WV thing) that my rear pads are at 4mm and will need to be replaced soon. I'm inclined to just replace the pads leave the rotors alone.
#238
The other option is have someone resurface your rotors, but you need to find someone who does it well and is worth the cost. I have never had that done b/c I don't trust the places that do it.
When I just did my rear brakes I considered just doing the pads, but again, now that I am retired my mileage is much less, so a brake job is probably going to be every 4 or 5 years, and the price per year is so small that I just put on OEM rotors for peace of mind....I know that they work and will last me at least 70k.
bamalam (02-26-24)
#239
I just replaced my rear pads at 68k....pretty worn with only 2 mm left. I assumed that the fronts would be well worn so I planned on doing those yesterday. When I got in and measured they all still had about 7 - 8 mm of pad left.
Good news but I was somewhat surprised since I always remember my fronts wearing out sooner than the rears on other vehicles.
#240
Just curious....how are your front pads doing?
The following 3 users liked this post by jcg0324:
